And just as I thought..
Old Aug 2, 2008 | 04:15 PM
halfofalmost's Avatar
halfofalmost
...I had the money to fix/replace my low speed fan assembly, something is wrong with my clutch? Or something?
I was on my way to work this morning, downshifted to take the turn around right toward the frontage road leading to my store, and my car pops out of second gear. I try putting it back into second gear, and again, pops out. It will not stay in second gear at all now. Drove it home nursing it from first to third and so on. Second gear just wont stay in.
I pray its just the clutch or something even more simple, anybody else have this problem?
Old Aug 2, 2008 | 07:48 PM
halfofalmost
Sad panda :(
Old Aug 2, 2008 | 11:59 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
2nd gear syncros might be bad. (>_<)
Old Aug 3, 2008 | 06:36 AM
halfofalmost
Is that a sign of a failed transmission?
Old Aug 3, 2008 | 11:21 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Well, what is your milage? Driving style?
If it was something with the clutch master or slave cylinders, you'd have trouble with other gears as well, or couldn't get into a gear. Since you can use the clutch normally to get into first, start and shift about, I think that those cylinders are ok.
Poping out of a gear could only be something with the linkages or the syncros. I'm sorry to say that if one syncro is bad, the entire transmission is done because the syncros are not available seperatly.
However, you could get a dog engagement set from Quaife. You'd have a hard time breaking those no matter how you drive.
Old Aug 3, 2008 | 12:48 PM
halfofalmost
to be completely honest, it doesn't see the track, but I do drive spiritedly. 51k miles
Old Aug 3, 2008 | 02:42 PM
Juiceman's Avatar
Juiceman
Try double clutching to second.
Old Aug 3, 2008 | 08:13 PM
halfofalmost
I've read some seriously high prices quoted online for replacement/rebuilt transmissions.
Most are on consumer websites, anybody else have charges they've incurred replacing a tranny? 04 r50 is the midlands trans, right?
Old Aug 4, 2008 | 07:03 AM
chadtoolio's Avatar
chadtoolio
THis has a midlands in it...All the syncros, etc...are available. Check realoem.com
Old Aug 4, 2008 | 09:37 AM
Ancient Mariner's Avatar
Ancient Mariner
Throwout bearing going bad will also cause that kind of behaviour. Starts with one gear, then sooner or later (usually sooner) all the gears are affected.
But with the Midlands, all bets are off. That tranny goes south more often than not.
Old Aug 4, 2008 | 12:16 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I assumed it was the Getrag. oops.
Old Aug 7, 2008 | 10:58 AM
halfofalmost
Diagnosis: dead tranny.
Price: $4800 at the Mini dealer.
Any suggested/recommended alternatives? Like the uprated midlands from Mini Mania? And a shop in texas known for quality work?
DmOcRsI
Jun 24, 2015 03:14 PM
Jack$0n
Factory JCW Talk (2009+)
38
May 15, 2012 04:35 AM
Coen_de_K
Oct 11, 2007 03:41 AM
Hogtied
Jun 23, 2007 04:24 PM
