scan tool reading P2301&P2304, ignition failure?
Old Jun 11, 2008 | 04:26 PM
canyonking's Avatar
canyonking
so basiclly my car stalled the other night, wont start, towed it home, did all the usual inspection and then i plugged in my scan tool....It's showing a fault code of P2301 and P2304......these codes indicated that "ignition coil A & B primary circuit high"......i was just wondering what this means and how it can be fixed. A couple years ago i had spiliced into some wires for what reason i dont remeber, but why would it be affecting it now? i checked all the fuses and none are blown.....i had an MSD coil pack but once this happened i reverted to the stock one....also have 8mm upgraded wires and iridium plugs, but that cant be the problem.....
thanks in advance for the help
Old Dec 11, 2016 | 04:58 PM
sheldon-w-allen's Avatar
sheldon-w-allen
Late as ever, but I'm having those codes right now. Car won't start despite new fuel pump/filter, and plugs.
Old Jul 5, 2018 | 11:42 AM
Revevsi's Avatar
Revevsi
Was this problem of vehicle have code p2301 and p2304 ever solved, because I’m haveing the same issue and can’t seem to find someone that has had this problem and fixed it?
Old Jul 5, 2018 | 04:04 PM
downshift1's Avatar
downshift1
usually it's a coil failure
Old Jul 6, 2018 | 07:50 AM
Revevsi's Avatar
Revevsi
I have already replaced the coil pack, and still get the same two codes. And my scan tool is getting other codes which leads me to believe my dme is communicating?
stevepsd
35
Dec 6, 2022 03:22 PM
DeniseNY R52
May 17, 2016 05:16 AM
AdrenaliNate
Nov 4, 2015 07:26 PM
R56BrgMcs
Oct 6, 2015 07:10 PM
