DEAD CAR!!!!!!
Old Jun 14, 2008 | 05:12 PM
silversmoke06's Avatar
silversmoke06
DEAD CAR!!!!!!
Please help me.
I have a dead car.
Today after work i went to leave. Put the key in turned to start and nothing.
all sorts of pump and spinning noises but no clicking or turning over.
I did however do a cam swap the night before. but i cannot find any missing or loose clips anywhere. i don't know if theres something i can look for to see if it is a possibility of a current leak.
I did replace the battery today with a brand new one.
but I got it started on a fluke at work and hasent wanted to turn over since.
I have it on a charger right now but the brand new battery seems to not have a lot of juice.
I am thinking i either have a burned Alternator or i have a bad starter/soilnoid.
If anyones got a clue or if this has happened to you please let me know.
Thanks in advance, Im hopin the mini community can pull me thru!
Colin
Old Jun 14, 2008 | 06:06 PM
canyonking's Avatar
canyonking
same thing just happened to me......i thought it was the alternator then the cam and crank sensors and then i scanned my computer and my ignition fault code came on....so i took it to the mechanic and 2 days later he called with the bad news....apperintly just a short power surge can fry your DME(computer), he said he found fried capacitors and itll cost around $1600 to replace...best thing u can do is scan ur ECU and take it to ur mechanic and hope for the best
Old Jun 14, 2008 | 11:34 PM
silversmoke06
I got it. thanks to a good friend he pointed out a slight oversight that occured during a late night Thrash to get my car buttoned up after a cam swap.
The ground wired on the pass side engine mount is apparently very important.
So check yours today!
minipopkart
Aug 13, 2015 05:22 AM
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
CARdiac
Aug 8, 2015 03:30 PM
PatrikKN
Aug 5, 2015 09:10 PM
