DME question
Old Jun 14, 2008 | 03:21 PM
canyonking's Avatar
canyonking
DME question
so found out the reason my car wont start is cuz my DME blew 6 capacitors .....now the tech says a new ones like $1230 plus 2 hours of install and labor......now i was wondering if theres a cheaper fix of another type of computer that wouldnt be this much....cuz if i had this much cash to throw around my car would never bee in the shop...thanks in advance
Old Jun 14, 2008 | 10:22 PM
guidmini's Avatar
guidmini
DME smoked
Cayon no way around it. I just installed a new dme on a customer with a 2003. it was smoked. Its exactly what you say same $ plus 2.0 labor and programming. Not really sure anything aftermarket for less to replace your
oem DME. I say put it on your card and pay a little @ a time.
Other than that. see what the guys who are racing theres on track if they run a oem or something different. Also. Speak to Jan @ RMW maybe he might know someone. Say you went to get a junkyard or used one. You would also the new the key module(EWS) and the key ring that goes around the the ignition switch. then with those 3 items it will work.
but not sure what it would cost may not be worth the $.
Good luck
Guido
Old Jun 15, 2008 | 04:32 AM
chadtoolio's Avatar
chadtoolio
Good luck
Guido
Your right about the EWS and the DME, but the Torroidial coil(the ring around the ign. switch) is not needed. It only sends the key data to the EWS, and has nothing to do with determining if the key goes to the car. It wont care, put the wrong key in...it'll send that data too.
Also, do you carry around 2 keys..one for the ignition and the original for the door locks.
And to add one more thing, since all keys are matched to the EWS and the EWS is matched to the VIN and all keys must be ordered with the VIN. The customer must provide proof of ownership of that VIN and if after this install, he lost his key and couldn't provide proof of ownership he couldn't get another key.
Best bet is to get the right DME
Old Jun 15, 2008 | 03:11 PM
canyonking's Avatar
canyonking
ok yea i think im going to just og with the new DME then...just have to bite the bullet if i wana keep my baby running...thanks alot for the help guys
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
PSU 98
Sep 11, 2015 11:20 AM
cinnabun
Sep 11, 2015 05:55 AM
marc0011
Sep 10, 2015 10:04 PM
