Is it possible to fix a loose Glove Box latch?
My latch is really loose. I readjusted the catch pin so at least my glove box stays closed but when open the lever is quite loose. Is there a way to take the glove box apart to get to the latch?
Yes, I had to remove my glove box a couple months ago because it would not stay closed. I removed it "the glove box" and repaired the latch. its is somewhat adjustable. I forgot, I have a 03, I think they may have changed them in 05. I actually ground the base of the latch down to have it hang alittle lower, seems to be working ok, good luck.
I know this might be a bit ghetto but I fixed mine by screwing in a screw where the door meets the latch. The screw went into the latch and not the glove box door. The screw head hooks onto the door when closed and no I have no problems.
When mine broke, I knew the latch was broken, so I "broke" the door: carefully breaking each plastic weld till it came apart. Then I glued the latch back together. Then I glued metal reinforcements into key locations on the latch. Then I drilled a pin into the latch where the springs attach. And finally I glued the whole thing back together. I just completed this 2 weeks ago so I don't have any long-term data, but so far it's holding up fine.
The latch handle breaks inside the door which is glued together(common on 03's ,bad design).just like david said.It is unnerving to brake appart the door but not to hard. start at the hinge side!I did mine a month or two ago and it still works great.I used 5 min epoxy others have used jbweld.Or you could buy one new for $260. from the dealer.Peter
I had this problem on my '03. I did a search and found an easy fix - only took a few minutes.
Here's the link to the fix:
http://nemini.org/index.php/topic,2747.0.html
I peeled my GB door apart this afternoon. The latch is of course broken. Epoxying that now. But I was thinking tonight what to glue the door back together with. Don't want it to be too well glued - may have to get in it again. Epoxy? No. Super glue? No. Hot Glue? No. Maybe just glue at the edges so breaking the glue again will be easier. Suggestions?
i cracked my door open and glued it back together as described here. it has been holding up for about two months. i used jb kwik, not sure if there is something better. it beats shelling out $280 for a new glovebox!
Glove Box Flying Open versus Whimpy Latch
There seems to be two topics going on here and it's worth clarifying.
1) Glove Box Flying open:
The middle of the thread has a pretty good link that gives instructions on how to take the glove box out. But many times you can avoid pulling out the entire glove box if you just do as the OP wrote --- readjust the catch pin.
If you look at the top of the glove box, there is are two screws that can be loosened. DONT totally unscrew them or you will have to pull the glove box out, but if you just loosen them then the catch pin is adjustable. Slide it back and forth and you can make the catch more or less secure
2) Whimpy Latch:
Replace the unit or Bust it open and Jerry rig a replacement/solution
2) Whimpy Latch:
Navigation & Audio iPhone5 / Lightning adapter for OEM ipod interface
ROCNDAV
Oct 20, 2015 01:08 PM
