AC system blockage?
Old Jul 17, 2008 | 05:24 PM
socalsurf's Avatar
socalsurf
AC system blockage?
I just bought a 2003 Cooper and have some problems with the AC not blowing cold. I took it to that local mechanic who evacuated and recharged the system. No leaks, holds pressure well. Compressor turns on but it doesn't blow cold. He said that there is a blockage in the system and that it probably need to have the receiver/dryer replaced and possibly the expansion valve/orifice.
Has anyone seen a similar problem? Suggestions?
I am in Southern Orange County CA and could use a recommendation for an independent mechanic. Any experience with Irvine BMW/Mini dealorship?
Old Jul 17, 2008 | 06:55 PM
chadtoolio's Avatar
chadtoolio
Is the cooling fan coming on? What are the pressures when running?
Old Jul 17, 2008 | 08:02 PM
andrewholmes's Avatar
andrewholmes
i had mine start to blow "warmer" and it turned out to be a totaly pluggud up cabin filter. cant hurt to try
Old Jul 21, 2008 | 12:03 PM
socalsurf's Avatar
socalsurf
Yes the cooling fan comes on, the compressor engages. It just doesn't blow cold. The AC Tech did a complete evacuate/recharge to the specified pressure (from the sticker under the hood, (91 psi +/-2?) but said that there was a blockage somewhere in the system.
Old Jul 21, 2008 | 12:04 PM
socalsurf's Avatar
socalsurf
Where is the cabin filter locate and how do you access it to replace?
Old Jul 21, 2008 | 04:42 PM
k-huevo's Avatar
k-huevo
It is possible the expansion valve is blocked. Unscrew the dryer, look for grey stuff on the end, if it is dirty, the desiccant has probably spilled and entered the system. The dryer is easy to replace, but the expansion valve is located under the driver’s side dash, not so easy; you will need new O-rings and adaptor plate also. The dryer and expansion valve are pricey items of around $150 or more each.
The cabin filter is located under the glove box; pull one side of the lid from the tabs, and then the other, remove the filter and see if that helps.
Old Jul 21, 2008 | 04:57 PM
socalsurf's Avatar
socalsurf
I just pulled the cabin filter and it was very dirty. I am sure it has been restricting air flow. I will replace it and see if that helps. Thanks for the heads up.
bahman
Nov 15, 2019 05:45 AM
Filmy
Sep 7, 2015 08:27 PM
Filmy
Sep 7, 2015 11:27 AM
Sep 4, 2015 02:34 PM
M7Speed
Sep 4, 2015 10:47 AM
