High RPM at cruising speeds - Clutch Problem?
Old Jul 21, 2008 | 09:34 PM
tahoerdr's Avatar
tahoerdr
2003 cooper manual tranny. Never tracked or driven too hard.
No engine codes.
While at cruising speeds of 70-75mph, the engine is at around 3800 RPM; way higher than usual. This happened practically overnight, it wasn't a gradually worsening problem. I can only guess it's a failed clutch.
I had a jeep that had a similar problem with no codes. It was a bad throttle positioning sensor. Do MINIs have one of these and where is it?
Do you think low tranny fluid could cause it?
Do you think cruising at these RPMs on the highway for 25 miles is going to damage the clutch?
Old Jul 21, 2008 | 10:04 PM
AliceCooperWA's Avatar
AliceCooperWA
If it is the clutch, it means that it is slipping. The first thing you should do is see if you can get it to slip. Try doing a run in 3rd gear from 3k to 6k rpm and see if you can feel it slipping. There is no way that the clutch will simply stay at the wrong rpm in a manual. If it is constantly slipping, you would smell clutch burning all the time. Even if your clutch is slipping really badly, if you let up on the gas while cruising, the rpm will drop to match the engine speed. It will only slip under power.
Old Jul 21, 2008 | 10:56 PM
silversmoke06's Avatar
silversmoke06
mine did that.
Its not doing it now.
However i do have a stage4 clutch to rep.ace it.
Old Jul 22, 2008 | 12:52 PM
tahoerdr's Avatar
tahoerdr
Thank you for the responses. The issue showed up yesterday on my commute home. The problem seems to have disappeared today.
Bublik
Feb 18, 2023 11:09 AM
Svejk
Feb 24, 2019 12:18 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
wind715
Aug 11, 2015 07:56 AM
