Jerks when driving
Old Aug 13, 2015 | 10:10 AM
Bublik's Avatar
Bublik
Jerks when driving
Hi, guys!
I apologize for my English
I own a Cooper S 07/2004, MT. VIN - TD31335.
Recently the problems started.
When driving from 3rd to 6th gear, there are jerks. On 1 or 2 gear were a couple of times.
When the car warms up and I start to go quickly, see a spurt in the range of 2000-4000 rpm.
The car on the gas pedal does not respond.
The car jerks, the speed drops, the rpm is not changing. After 1-2 seconds all ok :(
Ignition coil, high voltage wire and spark plugs - new.
The throttle is clean.
Tested the car with Rheingold, no errors.
Asking for your help.
Old Aug 13, 2015 | 01:01 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Water in fuel? Fuel filter clogged?
Old Aug 13, 2015 | 01:04 PM
Helix13mini's Avatar
Helix13mini
Jerks would be indicative of misfires, which should throw codes. You also could be getting excessive detonation if it's happening at low engine speed and wide open throttle.
Old Aug 13, 2015 | 01:31 PM
Teh's Avatar
Teh
Now is it a literal 1-2 seconds? Or is it almost a second?
Bypass valve? Does it seem like more of a hesitation in the engine? Like a hang up?
Did you check to see if your MINI stored codes? If it really is a misfire, it'll store a code rather than come up as a Check Engine light because it wasn't major enough for it to stay. How quickly does your speed drop?
Does it only happen when boost is being built up too quickly from the SC? I.E. Wide open throttle at 2500rpms-3000rpms exact, and is it nonexistent past 3000rpms?
I'd say BPV but I kind of doubt it?
Throttle body maybe?
Old Aug 14, 2015 | 01:44 AM
Bublik's Avatar
Bublik
The fuel filter is clean. Changed 10 miles ago.
Old Aug 14, 2015 | 01:49 AM
Bublik's Avatar
Bublik
That's the problem.
No throw codes :(
Jerks is not at low engine speed, but in 2000-4000rpm the range.
Maybe I incorrectly said, but not detonation, like if someone pressed the brake.
Old Aug 14, 2015 | 01:56 AM
Bublik's Avatar
Bublik
1-2 seconds in this example.
Bypass today will check.
No error codes.
What is SC?
Vibration on the engine - yes. Engine mount is all new.
Most fun:
1st gear - all rpm OK.
2st gear - 2000-4000rpm problem, when the engine is very hot.
3rd-6th gear - 2000-4000rpm problem, always.
Old Aug 15, 2015 | 03:50 PM
one73ronin's Avatar
one73ronin
I've had this issue recently, and it ended up that the spark plug wires, after I had changed the plugs, we not seated correctly (pushed on hard enough). Although you've changed the coil and wires, make sure they snap on correctly. Another issue that brought me to this was a low or rough idle (around 800-900 rpms). One I got them on correctly it all cleared up.
Old Aug 16, 2015 | 01:05 AM
Bublik's Avatar
Bublik
The problem was on old the plugs and wires. New nothing has changed, then the problem is not here.
Old Aug 16, 2015 | 12:58 PM
one73ronin's Avatar
one73ronin
seems like we have a communication problem....
Old Aug 16, 2015 | 01:10 PM
Bublik's Avatar
Bublik
No, it's my bad knowledge of English. Sorry.
I mean.
The problem existed on the old spark, wires and the ignition coil.
The problem now exists on the new spark plugs, wires and ignition coil.
I checked all the connections between the wires and the ignition coil.
Old Aug 17, 2015 | 09:00 PM
one73ronin's Avatar
one73ronin
I wish I could help more, try doing a search in the forums for "yo-yo", I had a similar issue, I had tried cleaning the throttle body, cleaned the air filter, replaced the bypass valve, replaced the fuel filter, changed the plugs, I was thinking about changing the wires and ignition coil, butt like I had mentioned before, I just reseated them and all was good.
Good luck
Old Feb 17, 2023 | 10:22 AM
Susanagar82's Avatar
Susanagar82
I had the same issues with my mini Cooper the jerking between 1000 rpm and 2000 and I change the spark plugs … it took me 10 minutes . Took it for a drive after it and it runs perfect now .
Old Feb 18, 2023 | 11:09 AM
Daftlad's Avatar
Daftlad
Everyone else on the road is a jerk when I'm driving.
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
Aug 19, 2015 09:12 AM
Emnotek
Aug 13, 2015 05:47 PM
xpunisherx
Aug 10, 2015 10:50 PM
