How to remove the seat protection ?
Old Jun 11, 2008 | 10:29 PM
ColinBrussels's Avatar
ColinBrussels
Hi ! The back of my seats are scratched, I'd like to remove these plastic protections. I took the seat out of the mini, but I can't split seat and protection !
Help !
Old Jun 12, 2008 | 08:18 AM
thatatvguy's Avatar
thatatvguy
It's my understanding that they are only "clipped" onto the frame of the seat.
So, get your fingers in between the seat cover and the plastic backing and yank.
Someone please correct, if I'm wrong.
Old Jun 12, 2008 | 10:00 AM
ColinBrussels
Then it might be very hard clips, cause I tried and I almost cut my fingers !
Or maybe there is a special way to unclip...
Old Jul 8, 2008 | 05:34 PM
thatatvguy's Avatar
thatatvguy
Sorry for the delay. I have been trying to get these things apart to clean them for a while.
Here is a pic that shows the rear panel and the tabs that keep it on.
Here's a so-so shot of the lower part of the panel. Be careful when you pull. The panel needs to be lowered so the two tabs (one on each side) won't be damaged.
Nonetheless, if you grab either side of the top of the panel (near the headrest), grab and yank. Just be careful.
Old Jul 8, 2008 | 05:36 PM
thatatvguy's Avatar
thatatvguy
Here's pic of the whole frame.
No wonder they're heavy.
At least they are not flimsy.
Old Jul 9, 2008 | 10:00 PM
ColinBrussels
Thanks for this explaination !
To make sure I'm right, first I pull the top of the back panel, and then I lower it to remove the bottom. Right?
Old Jul 10, 2008 | 12:29 PM
thatatvguy's Avatar
thatatvguy
That's correct. Top needs to be pulled first. That will result in the
first pic you see. There are two stubs/fingers though.
Also, if you are going to remove the whole back piece, you will need to remove both side adjustment *****. I only removed the one with the screws exposed - this let it rotate back enough for me to work.
flyers47
Jul 27, 2020 02:38 PM
Dec 23, 2015 10:36 AM
Zettinger
Aug 25, 2015 04:04 PM
greekzilla
Aug 23, 2015 03:44 PM
DWooderson
Aug 10, 2015 09:12 AM
