Strange Noise from Drivers side Back
Old Jun 25, 2008 | 05:05 PM
Jtrem's Avatar
Jtrem
I have noticed a strange (metallic grinding) sound coming from the rear drivers side of the car. The noise is very odd. I have jacked up the car and I have found nothing that would cause the sound. It happens when the car is in motion (In or out of gear) The sound will stop when I brake. So it could be something to do with the brake system. Any ideas?
Thanks,
John
Old Jun 27, 2008 | 12:07 AM
Jtrem's Avatar
Jtrem
Any ideas? Still happening. If its still there after I replace the rotors and pads ill take it in I guess.
Old Jun 27, 2008 | 06:53 AM
Xymox's Avatar
Xymox
I'm guessing stuck pad/caliper or new rotors and pads like you mentioned.
Old Jul 30, 2008 | 12:32 PM
jameslew's Avatar
jameslew
Did that address your problem? I'm having a similar issue, although mine seems to be more about after I let off the break on a full stop...
Old Aug 1, 2008 | 10:16 PM
Jtrem's Avatar
Jtrem
Had the same problem your describing. I replaced the rotors and the noise was gone. My back driver side rotor was warped up the A$$!!!
Old Aug 2, 2008 | 07:36 AM
AutoXCooper.com's Avatar
AutoXCooper.com
Why was it warped? Did the caliper go bad or pad get jammed or
Old Aug 3, 2008 | 11:56 AM
Jtrem's Avatar
Jtrem
Honestly I have no idea. The rear rotors were pretty old though. IF it happens a again then I will know something is wrong with the caliper. lol
maestro39
Oct 27, 2015 02:38 PM
one73ronin
Aug 19, 2015 12:36 PM
cm.d
Aug 19, 2015 08:51 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
messyjesse96
Aug 12, 2015 05:51 AM
