transmission problems 70K ... is this common?
Old Aug 14, 2008 | 02:50 PM
MINIATR's Avatar
MINIATR
If it turns out we need to have work done on our transmission.... Is this a common problem? We are thinking of repairing this mini and getting another mini for our second car ... we love driving the mini. Does anyone know if the current models have less issues?
Last edited by MINIATR; Aug 18, 2008 at 09:05 AM. Reason: correct spelling/wording
Old Aug 14, 2008 | 02:54 PM
Xymox's Avatar
Xymox
For the average driver, stock Mini clutches tend to last just short of 100,000 miles. Even the Cooper S clutch will usually last more than 70,000 miles. Aggressive performance drivers and inexperienced drivers should not be surprised to get considerably lower mileage.
http://www.clutchwizard.com/mini.htm
Old Aug 15, 2008 | 02:05 PM
ofioliti's Avatar
ofioliti
The OP wants to know about the transmission, not the clutch.
(I have the S and have not read up much on the Cooper transmission. Sorry)
Old Aug 15, 2008 | 03:27 PM
Xymox's Avatar
Xymox
So are you saying you don't feel the clutch and the transmission are related?
Old Aug 15, 2008 | 03:28 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Originally Posted by MINIATR
Found out we need a new transmission at 70K for our 03 cooper. Is this a common problem? We will probably by a new car ... we love driving the mini. Does anyone know if the current models have less issues?
Yes it is. If it's the automatic or the 5 speed midlands one of which would be in an 03 Cooper. Good News if it's the 5 speed the rebuilt is better then the OEM. The Bad News, it's can only be ordered from a MINI Dealer. You can have a non-dealer do the work, but don't think you will save money buying the trans from a non-dealer. Unless you buy one out of a junk yard. Shop around the area and check with local MINI owners to try and find someone that's done one it might save you some cash. While the MINI is in a million parts it would be a good time to change the clutch too.
Old Aug 15, 2008 | 04:28 PM
Jtrem's Avatar
Jtrem
If its the midlands 5 speed then yes it's common for it to fail.
Old Aug 15, 2008 | 05:41 PM
ofioliti's Avatar
ofioliti
Of course they are "related," but the poster wants to know about the transmission.
Old Aug 16, 2008 | 04:50 AM
cheesyman's Avatar
cheesyman
I used to own a '04 Cooper CVT (Built: Jan '04) and the transmission was changed twice! The first one was changed around March '06 (Mileage ~ 30,000 miles) and then changed again around Sept '06 (Mileage ~ 40,000 miles). Thank God the first change was covered by factory warranty, while the second change was covered by parts replacement warranty.
I have since disposed of the Cooper.
Old Aug 16, 2008 | 04:57 AM
cheesyman's Avatar
cheesyman
Forgot to add - replacement factory parts like transmission, engine are typically "reconditioned" over here in asia, even though its covered by warranty and the job done by the dealer. yes, the replacement parts came from germany, but they are never new ones.
according to the dealer, faulty parts are shipped back to germany for repair and once repaired, will be used as replacement parts! not sure if that is the same practice in the States.
Old Aug 16, 2008 | 10:00 AM
Jtrem's Avatar
Jtrem
I think most of the parts we get here are brand new. I'm pretty sure the Trannys are new as well, because you can get a re-build one cheaper.
Old Aug 16, 2008 | 09:41 PM
cheesyman's Avatar
cheesyman
that was what the dealer initially told me - parts are new, but when i chose to inspect the part prior to installation, i noticed there were marks on the nuts and bolts. it was then the Mini dealer let the cat out.
a quick check with Honda in my country reveals the same practice!
Anyway, it could be limited to this part of the world, due to the high import tax rates. Imagine we paid close to US$72,000 for the R56 MCS! Back in 2004, the R53 was US$63,000! And half of that goes to the Government. WTF!
Old Aug 17, 2008 | 09:36 PM
heyduard's Avatar
heyduard
Just a Cooper? Midlands tranny is problematic. Mini switched to Getrag asap for the 05 and onward. MCS started with Getrag from the start. If auto, the CVT was dumped for Asin units.
All new manual MNIs come standard with 6 speed getrags. Asin for the automatics.
Old Aug 18, 2008 | 05:34 AM
thulchatt's Avatar
thulchatt
I had a 'replacment' trans put in a Honda under warranty and it has been fine over 50,000 miles. Most manufactures need to do something with the returned warranty trans and just rebuild. In many cases the rebuilds are as good as or better than new, our Honda trans is.
lalroma
20
Apr 2, 2022 06:19 PM
phrza81
Oct 10, 2015 11:37 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
