Need some Help ID'ing a Part
Old Jul 20, 2008 | 08:51 PM
Jtrem's Avatar
Jtrem
Okay so I have been having trouble with some oil leaks and oil pressure issues for a week now. I've had it where the light comes on at idle then goes away went accelerating. Anyways Im pretty sure I know what the problem is. Last time I had someone change the oil they threw away this part The black perforated piece. So when I went to do an oil change I discovered the leak along with oil canister being torqued to over 100lbs Anyways I just wanted to know if anyone knew the name of that part and if it can be ordered at the dealer? Id appreciate it.
Thank You,
John
Old Jul 20, 2008 | 09:15 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
You're going to have to buy the enitre fuel filter housing assembly at great cost. Then, never let anyone change your oil but yourself.
Old Jul 20, 2008 | 09:20 PM
Jtrem's Avatar
Jtrem
That sucks. Maybe I can get around not having it. The filter worked before with no problems.
Old Jul 20, 2008 | 09:23 PM
COR BLMY's Avatar
COR BLMY
may want to try contacting Mini recycling .800.926.5900, they ship ...
Old Jul 20, 2008 | 09:25 PM
Jtrem's Avatar
Jtrem
can anyone get a part# on this? I tried RealOEM but there site is down.
gnatster's Avatar
gnatster
It comes with an assembly. That Part # is 11-42-7-563-763 and they run about 45 bucks.
Classic and Morristown both will give discounts to NAM members and shipping wise Classic in OH is closer.
Real OEM was down to you cause I was on it at the same time and used the entire bandwidth bwahahaha
http://www.realoem.com/bmw/showparts...95&hg=11&fg=30 is a link to what you are looking for.
Old Jul 20, 2008 | 09:28 PM
Jtrem's Avatar
Jtrem
Thank You So much Gnatster!
Old Jul 20, 2008 | 09:47 PM
COR BLMY's Avatar
COR BLMY
Yeah no # on the actual part you need.
Try the # I posted above
Old Jul 20, 2008 | 10:18 PM
Jtrem's Avatar
Jtrem
Thanks Again. Ill get the mini recycling a call tomorrow
bobbiemartin
Jan 20, 2016 05:28 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
Ryephile
Aug 25, 2015 06:51 AM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
