View Full Version : Stock Problems/Issues
- AC condenser
- Help me save my Mini
- Radio Problems
- Fender Reflector Replacement
- Coolant Leak? on driver side footwell
- Supercharger/ water pump gear failure? What's the fastest it's happened?
- Drivers seat will not adjust
- 02 mcs, stalled and wont start
- Rear Brakes Screeching,,, Parking brake?
- 02' "s" ac not blowing cold
- Clutch "thunk" problem
- 3rd brake light
- Another Oil Change Question
- another window failure
- Air bag issues?
- JCW intake install, ECU connection help?
- AC Recharge
- Engine light - BMW puzzled!?
- Engine oil overfill?
- Clicking noise from throttle?
- Anyone remove the A/C from your street car?
- cooling fan replacement
- any help? persistent slow oil leak @ 29k
- Fluttery, farty sound when engine is loaded
- Expansion tank empties very quickly
- Brake Caliper Rebuild Kit
- Is it the transmission?
- OCC is blowing my seals. Or MINIUSA is blowing me?
- Do I need an alignment? (symptoms)
- Power Steering Pump Help!
- A baffling problem for NAM's brilliant brains
- Intermittent P0442
- Removing the dashboard airbag-warning sticker w/o making a mess...
- Key chip reprogramming?
- Help replacing Power Steering Pump Fan
- Leaking overflow tank cap? Picture
- Not happy with Alta tech support and customer service
- 3rd brake light dead
- 03 MINI fan won't go off!
- My Windows No Workie-Jerkie...
- Service Engine Light
- Clutch pedal
- EML in Reverse
- AC is busted Need help Locating Sensors...
- Transmission Fluid Change How To?
- Piston Rod Failure @ 48000mi?!?
- mini idiot lights?
- Oil Pan Gasket Replacement
- clutch help
- Clutch Master Cylinder Went
- Right side brake light out
- HELP! MINI Dramas of Fire/OverHeat/BadBlock!!!
- Glove Box Key Cylinder
- Electrical Gremlin...HELP!
- Drive Shaft
- SES light - off when filled with gas
- Misfire?
- Side Marker light
- Power Steering Problems
- E-Brake Light Randomly On and Off
- 02 mcs stalling upon starting
- cooling fan replacement steps - it is not as bad as you are thinking!
- Temperature Mometarily Went Up To High
- Drivers side window didn't work
- Engine Surge
- Loud tire noise and rear suspension 1" low?
- Swishing sounds from stop?
- clutch squeek help
- Diagnosis: wheel bearing?
- Exhaust Manifold Header Fitment Issues?
- How to Change a front wheel bearing?
- 04 MCS Mysterious engine light
- Brakes
- Oil light question-Important?
- Could i be losing Power?
- The clunker
- ?? Problem after replacing contol arm bushings
- Help Needed Glove box is stuck!!
- 2002 brakes
- Help Needed - no a/c, cd changer, mfsw controls, pass door lock
- Good MINI Repair Shop in Southern California?
- Flush Power Steering System ??
- how to replace 02 sensor
- How adjust aim of windshield washers?
- Antenna Broke
- Need Touch up Expert in Atlanta-rock chips-scratches
- check engine light keeps coming on
- Low Oil Questions
- Air conditioning hose rubbing issues!
- Newbie needs help: Steering Wheel Shake
- dealer service interval
- Changing out the SC
- Exhaust Brackets Rusted and Broke
- 3 Years and 69k Miles. Maintenance list?
- did my key just die?
- Misfire
- Passenger door is completely F***ED!!
- Emmissions Light after installing the Alta CAI ??
- a/c problems! My girls are mad!
- Creaks and rattling going on in steering column...
- clutch grab
- Intermittent brake "rumble"
- airbag issue
- Hatch will not close/latch
- Windshield smashed!!
- Alignment after clutch & flywheel change?
- Car Won't go into gear?
- high beam light wont turn off
- Serpentine Belt Tensioner
- Window Stutter
- Replace Fuel Filter
- Worried
- Defect Code Lookup Tool
- Sound of water sloshing around.
- problem car
- cooling fan question
- May need a new transmission
- electrical system blackout
- Radiator hose clamp riding on intake.
- Wiring chewed
- computer problems: is it just me?
- Just Another Day in Paradise (RH Xenon w/PICS)
- Another weird sound issue
- Sunroof won't close
- My PS pump adventure:
- UGH! How do you remove the power steering hose?!
- Urgent::::: How to take off Outer Ball joint from Front Control Arms?
- rebuild it
- Knocking from front left side....sometimes
- Lubing your door hinges
- power steering whine
- oil filter housing issues
- How do I fix this?
- Drivers door won't open!!!
- P1106 and P0107
- overheating w/out blowing fuse (I DID read)
- Blah! Brake fade
- 03 MCS ANOTHER OVERHEATING PROBLEM!!
- Dipstick part number?
- 2003 mini speedo
- Source for Rebuilt Power Steering pump besides BBA
- What in the world is going on?
- What is the warranty on a 06 Mini?
- Hard Acceleration Delay
- Fog light insert pushed in.
- Flickering Xenon bulbs - Cause?
- 02 MCS AC no workie!
- Strange noise when using A/C.
- Coolant Flush DIY?
- power steering
- Broken boot latch...
- Preemptive repairs?
- Bad Left Outer Tie-Rod and Left Ball Joint.. Replacements?
- airbag light
- 2nd Hand DME
- On start-up - scratching noise
- unexplained power loss
- Programming self locking doors....
- positive camber?
- Instrument Cluster
- Empty coolant reservoir
- Remote Oil Filter
- Aftermarket warranty policies
- It's Alive!! Well...almost
- Wheel Hub Failure
- Need a new battery...suggestions?
- Door locks bowden cable service bulletin
- Strange knocking in steering when turning left
- EML ON(not the usual stuff)Mini one r50
- power steering problems - please help!
- Strange Overheating Problem with Air On Only
- DEAD CAR, HELP!!!
- Beltline clips broken
- Creak! Anyone else?
- Power Steering Pump leak.
- Driver's Side Window Problems
- Rounded off brake bleeder screw
- How to bend a stainless steel hanger (exhaust)
- Car died on me today!
- MINI Won't Start
- OEM v. Aftermarket ballast
- clutch sweaking????
- tick-tick-tick sounds from left front brake
- Flywheel noise...technical service bulletin?
- Rear Wiper Blade Replacement
- WARRANTY ABOUT TO EXPIRE...ANYTHING I SHOULD CHECK IN PARTICULAR???
- So I just got it out of the shop
- Flashing or offed oil lamp on dash
- oil residue on engine
- 2003 R53 Misfire cyl#2,#3 Dead
- Squeal on start *oink**oink*
- Error Lights
- E-brake doesn't work on left hand side
- Door Lock
- Probability of Clutch Wearing Out
- Exhaust problem
- Driver and Passenger Windows
- extended warranty works!
- Remove and replace PS Pump
- Reverse Lockout problem..
- Radiator leak?
- PLEASE help (car won't start)
- Overheating - NOTrad fan, NOT ps fan
- Fan on, Fan Off. Fan on, Fan Off...
- Help me track down the source of a shimmy...
- Noisy dash? MINI has a fix...
- How to Lift my car to get under neath????
- What type of Anti-Freeze/Coolant to use?
- Rubber Strut mount torn- what Happens if I keep going?
- Valve Cover Gasket, Performance?
- New Owner, New Problems!
- ASC flashing during cruise
- Dealer Stumped: Thoughts?
- wtfBBQ windshield molding coming OFF!
- How difficult is it to change the valve cover gasket?
- no dash lights
- National Back Order for Bumpers?
- fuel cleaner
- Replacement of fog light
- Ripped off by Prestige!!
- Low compression in #4
- Window Issues
- What's that clicking noise?
- Airconditioning Question
- AC help? Whirring sound + weak cooling = ?
- Evap system leak
- grey plastic vaccume line under ic?
- is it just tire noise or something worse after rough bump...
- Vibration - sounds like rumble strips! 02 MCS
- Oil drain plug stuck... help!!
- Steering fan - doesn't move
- bad kitty?
- Airbag Light On - NO Fault Code!
- A/C Not cooling
- P0301 Code
- Power Steering Pump/Fan Issues
- Dinan CAI Filter Questions
- brake dust dirtying rims
- Pentosin CHF 11S
- Loaner Cars
- TICKING WHEN CAR IS OFF???????
- loose interior sunroof trim
- Heater stops working at idle, Engine overheating light comes on at idle.
- Rear Hatch won't open with lots of stuff stuck inside
- Something Fell Off!
- HID out!!
- Engine is louder inside cabin since Dual Mass Flywheel was replaced
- SES Code P0340 & Traction light
- I HATE my glovebox! Any fit-it tips?
