EML in Reverse
Old May 30, 2008 | 12:51 PM
hugh's Avatar
hugh
EML in Reverse
I have an 05mcs with 54k miles. When the weather is warm, 50 degrees or over, and I back down my sloped driveway in reverse with the clutch fully out, the car stalls and the EML goes on. This never happens when I drive in reverse on a level surface, only when I back down the driveway. And not when I back down in neutral.
Anyone else have this problem?
Old May 30, 2008 | 02:15 PM
Silent1's Avatar
Silent1
Are you in gear and letting the weight of the car act on the engine, or are you coasting?
It sounds like it could be vapour lock, which as you're not accelerating the fuel pump isn't supplying enough petrol, it pulls in air and stalls, the EML light will be a result of it going lean as it stalls.
To try it out, start the car, give a little rev for a few seconds then roll down, if it stays running then that's the problem.
Old May 30, 2008 | 02:20 PM
gnatster's Avatar
gnatster
Does it light up LME?
Sorry...couldn't resist.
wildwestrider
11
Jan 29, 2016 05:06 PM
vulkandino
Oct 31, 2015 08:29 PM
gknorr
Oct 1, 2015 09:20 AM
bahman
Sep 30, 2015 01:59 PM
ericf1993
Sep 26, 2015 03:58 PM
