Misfire?
Old May 27, 2008 | 08:30 PM
Myke@RPI's Avatar
Myke@RPI
Misfire?
Sounds like I have a cam in my car sometimes at idle but For What I know it is stock... it will start sounding like the timing is off and fire in bursts (instead of a smooth steady even firing sound) Any idea whata a matter? I have the iradium spark plugs and the mods in my sig, never use anything lower than 91 octane...
The weird firing/rough idle will go away and come back every once in a while, my a/f ratio is 11:1 but not really the same when i dynod all 3 pulls...
Any ideas?
Old May 27, 2008 | 09:29 PM
jaynicholson's Avatar
jaynicholson
No service engine light?
Old May 27, 2008 | 10:23 PM
Myke@RPI's Avatar
Myke@RPI
nope, but does my software delte the cel if i have headers? Actually my CEL went off with my bad 02 sensor before... hmmm
Old May 28, 2008 | 02:15 PM
91Eunos's Avatar
91Eunos
when was the last time you changed your plug wires? I just replaced my old 8mm Magnecor wires w/a set from Custom Mini Shop ... no more misfires/engine stumbling between 1-3K rpms under moderate load.
If you rule that out try to swap in a known good coil pack...
If it's a fueling problem vs firing (electrical) it gets more complicated but I'd start w/ the injectors (again check connections, swap in known good ones, check for leaks, etc.) and work back to the tank.
Old May 28, 2008 | 02:28 PM
Dr Obnxs's Avatar
Dr Obnxs
What plugs you running?
Densos will go bad pretty fast. If you have your old plugs give them a try. But misfires will throw codes for sure. Check the terminals on the plug wires for corrosion. Sand or whatever to clean them off.
Matt
Old May 28, 2008 | 02:40 PM
AKIndiMini's Avatar
AKIndiMini
There is a post (or maybe a sticky) around here somewhere for stumbling/stalling. My car will go from a perfect idle, to a rough idle (your description is spot-on with what mine does). Sounds like it's about to stall, but mine never seems to do that. Blip the throttle, and the rough idle (usually) goes away.
I took it in to the dealer for this problem, and they told me that it is "normal" for these MINIs to run rough occasionally. Others on the thread I mentioned have had their dealers reflash the engine controller to fix the problem.
Something that seemed to work for me: I fueled up once with regular unleaded (otherwise I use premium), and oddly enough I haven't had the idle issue since. No other changes to the car...
Might be worth it to look for that thread...I'll try to find it in a sec...
Fordgt4
Oct 10, 2015 10:42 AM
randeez
Oct 5, 2015 09:23 AM
dutchhome
Sep 30, 2015 07:17 AM
silence2-38554
Sep 28, 2015 12:19 PM
ShadyCoop
Sep 20, 2015 08:57 AM
