Side Marker light
Old May 27, 2008 | 08:10 PM
putttn's Avatar
putttn
Side Marker light
Is there a specific bulb for the side marker lights on the wheel wells?
Old May 28, 2008 | 05:14 AM
Alerious's Avatar
Alerious
From what the Bentley manual states, the side marker light is simply a 5W bulb.
GotMINI
Old May 28, 2008 | 09:43 AM
cycleway4's Avatar
cycleway4
#194 for clear bulbs......[the stock bulbs].........
and then if you have clear lenses, you can get #194 colored bulbs
Old May 29, 2008 | 11:20 AM
putttn's Avatar
putttn
I've never seen a "clear lens" on the side marker lights by the wheel wells
Old May 30, 2008 | 04:59 AM
cycleway4's Avatar
cycleway4
hi...there is a seller on Ebay that offers a set of 4 clear side marker lenses.....look pretty nice
Steve
Old Jun 12, 2008 | 05:49 AM
joelcseymour's Avatar
joelcseymour
Side Marker replacement - Rear
Came across your thread. So how do i get the side marker open to replace the bulb?! I broke one already, dont want to do that again!
Joel
Old Sep 25, 2014 | 04:14 AM
umberto's Avatar
umberto
how to remove wheel well lining to access the side marker bulb
2004MC ...front left side marker light out .....to remove the wheel well lining to access the bulb there are 2 or 3 connectors that look like plugs, not screws ...any tips on removing those without breaking them??
thanks
Old Sep 25, 2014 | 09:11 AM
N2MINI's Avatar
N2MINI
those are push-pin connectors. pry the center pin up with a flat head or specialty tool and then do the same to the flat/washer part of what is left and it will pop out.. Front side reflectors are easier to get to then the rears.
boostedhaze
Jan 2, 2018 07:26 PM
one73ronin
Aug 19, 2015 12:36 PM
cm.d
Aug 19, 2015 08:51 AM
OutMotoring
Aug 6, 2015 09:32 AM
