Hard Acceleration Delay
Old May 5, 2008 | 06:07 PM
mcsc_horns's Avatar
mcsc_horns
Confession, I like to play "red light grand prix" once in a while. Every so often however my car will pause/hesitate for a couple of seconds. When it kicks in, I get thrown back into my seat but I am curious as to what is happening and why it only happens once in a while.
Old May 5, 2008 | 06:12 PM
glnr13's Avatar
glnr13
it's your DSC. it's doing it's job to prevent loss of grip off the line.
Old May 7, 2008 | 10:18 AM
mcsc_horns's Avatar
mcsc_horns
Why would it be sporadic? Is it possibly CAI?
Old May 7, 2008 | 11:28 AM
bent tech's Avatar
bent tech
Turn it off.
Old May 7, 2008 | 12:16 PM
glnr13's Avatar
glnr13
nothing to do with your cai. turn off the dsc
Old May 7, 2008 | 02:46 PM
gvoelker's Avatar
gvoelker
could it be the yo-yo effect and maybe not dsc? turn it off, and if it's still happening then that may be the case.
Old May 10, 2008 | 04:29 AM
mcsc_horns's Avatar
mcsc_horns
I like this kind of experiment. Let me give it a few more days but so far, no hesitation.
Old May 12, 2008 | 02:13 PM
MrCooperS's Avatar
MrCooperS
Moderator
it's the dsc, it's sporadic because sometimes your wheels might loose grip on a road with a little more debris versus a really clean road that can give you a good start. =] i play "red light grand prix" as well.
Old May 14, 2008 | 12:37 PM
sequence's Avatar
sequence
replace the OEM throttle body with an aftermarket unit and this should go away. part of the hesitation problem is the less-than-performance-oriented throttle body and the crappy Siemens control unit. Any performance modder can give U more details.
Old May 14, 2008 | 12:40 PM
Guest's Avatar
Guest
I don't have any hesitation on my car and I have the OEM throttle body...
You need to tune it out, having a bigger throttle body isn't going to make it open faster.
Old May 15, 2008 | 06:26 AM
sequence's Avatar
sequence
Dude It's not a question of making it "faster," but making it *smoother* with no hesitations across the rpm spectrum....
...but then I see yr sig and all yr mods, no wonder!
OK then, add to my post "possible" causes for the hesitation is the OEM throttle body and Siemens control unit. Jeez Louise.
Old May 15, 2008 | 11:48 AM
MINIFVR's Avatar
MINIFVR
I played red light grand prix against a new Acura TL (which I also own) and I beat it. The TL could definitely beat my MINI but I narrowly beat him, surprisingly. He got behind me, stuck his hand out of the sunroof and gave me the finger! Some people have a hard time out there...geez...
Old May 15, 2008 | 07:08 PM
minjae's Avatar
minjae
ouch..talk about poor sport...
but i've had this problem when trying a fast go once it turned green but i lost power in the middle of second gear before changin to third..i gotta try turning off the dsc to make sure it's that and nothing else.
Old May 15, 2008 | 07:17 PM
lhoboy's Avatar
lhoboy
If you have a lead foot, turn off the DSC and modulate the throttle for maximum traction and acceleration. Use the DSC for slippery conditions only to enhance safety. (Now wait for the heated debate).
Old May 17, 2008 | 01:46 AM
checkmate2006's Avatar
checkmate2006
Slow is smooth and Fast is smooth
Fourflys
43
Oct 20, 2015 09:42 AM
navybsn
Oct 4, 2015 03:27 PM
FatherG
Sep 28, 2015 06:34 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
