clutch grab
Old May 14, 2008 | 05:06 PM
scotth42's Avatar
scotth42
clutch grab
i was wondering what would be normal clutch engagement? trying to tell if my clutch is low seems low to me maybe it's the difference between my last car
Old May 15, 2008 | 12:40 PM
diptenkrom's Avatar
diptenkrom
what exactly are you asking? pedal travel?
how low to the floor is it releasing/engaging?
Old May 15, 2008 | 12:53 PM
rallymaniac's Avatar
rallymaniac
I have almost the same issue. The clutch is just all over the place. Sometimes it grabs low with me almost stalling because of that and the other time it will grab much higher resulting in some tiny slip/overrev. This is probably the worse clutch feel I've had recently in any car. I'm pretty dissapointed, but i guess this is the way MINI clutch is. Probably weak pressure plate problem or some iffy clutch plate material. You can't even get the wheels to spin with fast shift to 2nd.
I don't need a performance clutch stock as it's kind of pointless in MINI but better/consistent feel would be appreciated.
Old May 15, 2008 | 01:35 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
How many miles on the car? Has the clutch slave cylinder ever been replaced? If not it may be something you want to look into. The symptoms you described could easily be the manifestation of a failing slave cylinder.
Old May 15, 2008 | 01:39 PM
rallymaniac
Car has 22500 miles and still under both factory programs. I'll have to address this at my Inspection I due in 5k miles. It's not major issue as it's very slight difference and regular person may not even notice but it sort of annoys me sometimes having driven better feeling cars in the past
Old May 16, 2008 | 09:05 AM
scotth42's Avatar
scotth42
this is what i mean it doesn't seem to slip just engage low or mid way if i try to let the clutch out fast the car bounces a bit through all the gears this is at higher revs but it is annoying. if i shift at 3000 it's fine higher i get that bounce or more like a shaking. not really a big deal i just was wondering if this meant my clutch might be going out
Old May 19, 2008 | 06:19 AM
diptenkrom's Avatar
diptenkrom
^^^^ could have something to do with rev level in relation to trans rotation. which will happen at higher revs, harder to rev match at higher revs.
rallymaniac - i would second the slave cylinder idea from above.
drrigg
May 27, 2022 03:31 AM
OutMotoring
Mar 3, 2017 06:29 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Sep 28, 2015 09:13 AM
