PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. Replacement battery options for MCS...
  2. Can the dealer re program cvt full-throttle shift points?
  3. Water leak from rearview mirror!
  4. starting issue - troubleshooting hints
  5. How to diagnose a bent axle?
  6. Clutch/shifting problem
  7. How to recharge MINI A/C? (instructions?)
  8. Best place to order OEM brake pads?
  9. re-emerging RUST
  10. '06 R53: What's causing the howling noise?
  11. Regular Scheduled Maintenance
  12. Oil pan 2003 MCS
  13. Clicking at low speeds
  14. Environmental air filter
  15. Air Conditioner Compressor vs. Mods - Dealer Warranty Issue
  16. Engine Leaking Oil !!!
  17. The EML Light keeps appearing?
  18. MINI logo on steering wheel peeling off
  19. Manually raise window
  20. Strange (but very fun) problem...
  21. Programming key for keyless
  22. Burns on air filter
  23. Intermittant AUX port failure- anyone else?
  24. '04 MCS with extended warranty. Opinions Please.
  25. So who's the wise guy that turned out the lights???
  26. Stranded! Blown Clutch?
  27. Automatic tranny on my 2005 MCsa has self-destroyed twice in three months
  28. Can I reset the SES light?
  29. How to get rid of this stuff on the exhaust?
  30. squeaking brakes
  31. Squeaky wheel!
  32. Cooling Fan Running
  33. Need Help - Please Read :) (Air conditioning causing EML Light?)
  34. Troubleshoot: Supercharger
  35. Power Steering Fan??
  36. Cooling Fan
  37. Car won't move... clutch issue?
  38. Is the fuel pump audible?
  39. Air conditioner/overheating Help!
  40. Clutch question - do-it-yourself replacement job?
  41. power steering fan ducting
  42. Bootlid stuck
  43. ticking/tapping under bonnet
  44. Help! Clutch and gearbox problem!
  45. Help, able to hand tighten oil filter canister yet
  46. Oil Filter canister ?
  47. Front end vibration/shimmy
  48. Oil Filters
  49. power steering loss help
  50. O2 sensor dead at 26k?
  51. Several clutch questions / possible issue
  52. Problem with my CVT transmision 2003 mini non-s
  53. Random/sporadic problems
  54. Wrong Forum
  55. Creaking dashboard
  56. window spray not working
  57. Is it the power steering pump?
  58. need help removing rear brake caliper
  59. SES light & other service issues - is it just me?
  60. Door lock problems
  61. Clutch Question
  62. New Clutch gone bad?
  63. Engine Starter Saga
  64. "Factory" ducting for PS fan?
  65. DSC, ABS, Tire Pressure Warning
  66. Heads up: Oil Leakage and Worn Control Arm Bushings
  67. Headlight washer bezel broke
  68. Rear Brake Friction
  69. '03 MCS Clutch
  70. corroding gas cap
  71. Help! Mice Damage
  72. Brecht MINI service left a bad taste in my mouth...
  73. electrical gremlin?
  74. door locks
  75. Is it from the A/C ??
  76. I don't know if this qualifies...
  77. Drivers side window squeal
  78. Trying to rule out a vibration
  79. clutch gear prob
  80. Rear brake pad clicking & loose
  81. MINI MAJOR DISSAPOINTMENT!
  82. i busted the tweeters...
  83. radio problems...
  84. Engine Problem
  85. Quick Tire Question
  86. Cooling system- white milky fluid?!
  87. Xenon Headlamp Issue
  88. Service engine soon P0031
  89. HELP car won't start
  90. Code P1476 ??
  91. Oil Filter is a PITA!!
  92. What brand coolant ?
  93. Odd problem with lights any ideas?
  94. Is my Oil Pan missing screws?
  95. Car Not Starting!
  96. Problem with washer fluid reservoir?
  97. !!!2004 ENGINE BLEW UP WARNING!!!
  98. Recall list
  99. PROBLEMS: Plz Help
  100. Pulling small trailer (900lbs)
  101. key cost
  102. Lights not flashing when I remotely lock the doors
  103. Schedule Maint List
  104. Can't get the expantion tank cap off!
  105. Recommended MINI Mechanics - Nashville?
  106. Oil Pressure light comes on
  107. Key Memory - not as described in manual... or the next manual
  108. Replace Bowden Cable
  109. O4 CVT-minor and major problems-Input?
  110. Brake Dust... how long?
  111. Broken Hood Scoop
  112. Vibration when travelling from 2k to 3k RPM
  113. Need "How to" instructions for PS pump replacement
  114. Help - my brake lights won't turn off
  115. Stalling Out while Braking
  116. rear exhaust issues?
  117. evidence of mushrooming?????
  118. The clock lights up but doesn't display any numbers
  119. Both Keyless remotes don't work! Rain?
  120. Question for MINI techs
  121. P0172 (Too Rich Bank 1) Troubleshooting Help Sought
  122. Anything made to replace oil-filled engine damper?
  123. 60K What needs replacing?
  124. Bushing Dilemna
  125. Engine Cooling Fan is Cycling
  126. Recommended mechanics Philly area?
  127. Speaker problem
  128. Problems with A/C. anyone else?
  129. Louder Exhaust Noise: Failed Muffler/Cat?
  130. My MCS is leaking!
  131. A Click everytime I accelerate or slow?
  132. bad oil leak help
  133. clutch, brakes and fair price 2002 coopers
  134. Motor Mount removal and replacement
  135. double post
  136. TB/BPV housing rusting
  137. Does this sound like I need a new clutch?
  138. 27k miles and feeling age
  139. What kinds of problems do Minis have after 100K?
  140. Oil plan plug stripped!!!
  141. Overheating problems '03
  142. Need Double-Pull Disable Instructions
  143. Stuck Brake-> Heat + Smell! Help!
  144. A couple of problems
  145. anyone know how to reset onboard comp
  146. idle question
  147. Rear/Tail Lamp Problem. Please help!
  148. Posi-drive NOT Phillips
  149. repairing runflat tires
  150. Oil drain plug
  151. testing tire pressure monitor
  152. 06 MCS shakes/rumbles with loud noise coming from engine?
  153. bypass valve was stuck - any unseen damage?
  154. Battery light and PS pump problem
  155. Car locked itself while running
  156. P0108 Code - definitive causes?
  157. Crankshaft or Idler pulley problems?
  158. The Burning Smell
  159. 06 Cooper 5 Spd Whines at Maintained Acceleration
  160. Xenon Headlamps for 2005-2006
  161. Winding Sound
  162. Odd sound even with engine off (but power on)
  163. 2007 MCSC Not Starting....
  164. Oil filter housing stuck ON - can't change filter
  165. Radio won't turn off!
  166. Clutch Problem
  167. Water intake problem
  168. Brake pad warning light
  169. Radiator Fan issues turns on after car is off.
  170. Power steering fan
  171. Rattling/Grinding noise at 40 MPH
  172. Questions About Stuff
  173. Hey guys Possible P/S and Engine Rattle..
  174. window auto down
  175. Bad fuel pump?
  176. Help! Can't open door
  177. Reverse switch installation help
  178. Creaking sound from rear wheels
  179. Navigation stopped talking
  180. steering wheel tilt not locking
  181. "Check Filler cap" light comes on!
  182. Oil leak
  183. Overheat
  184. "cricket" squeak from right rear
  185. Electric Window Problem?
  186. BMW mechanic with a mini problem relating to steering angle sensor
  187. MCSa Tranny Q
  188. Missing anything?
  189. Limp Home mode and SES light @ 5K RPMs
  190. Power Steering issue...different than most
  191. 06 with a cracked windshield - what do I do now?
  192. Uh-oh. Oil spots on the driveway.
  193. No A/C, HVAC flap stuck?
  194. What is this code and what does it mean?
  195. Anyone bringing a scan tool to the Dragon?
  196. Odd (gurgle) sound at higher rpm's
  197. Transmission Fluid Change?
  198. Nearing 36k miles - should I purchase and extended warranty?
  199. service egine light, summer blend gas maybe??
  200. Used car blues
  201. MCS - Front Squeaks When Turning Wheel
  202. Hatch goes "Boonk" - all by itself! (FIXED!)
  203. piece of gravel in pulley track
  204. clock problem
  205. MINI OBD II Scanner
  206. Creaking/crunching noise from right rear
  207. Voltage ?
  208. Shift cable broke
  209. problems with oxygen sensors!
  210. 2003 Mini Sport advice needed
  211. New door = airbag light on
  212. "Serve Engine Soon" went on!?!?!?
  213. No Heat after Dash Work????
  214. oil cooler leak (major)
  215. tires rolling
  216. Oil in coolant problem
  217. AIRBAG LIGHT WENT ON FOR 3 MINUTES
  218. Sunroof problem closing
  219. Seat heater woes
  220. Brake Booster...possible issues.
  221. Freak'n Window
  222. Help! Window! :)
  223. JCW Carbon Fiber question
  224. Dome Lights Burned Out
  225. Is this a big problem?
  226. cooling fan
  227. cooling fan
  228. Strut mount mushrooming, no big deal?
  229. Any idea what would cause this? BC1?
  230. Is it a Broken Engine Mount? (picture included)
  231. Dealer Programming Options--takes a whole day???
  232. Wiper issues - help neede
  233. Service Engine Soon Code P0456
  234. Boot/Bonnet Warning Light
  235. Anyone Encountered This? Motor sound after engine start or shut off?
  236. Front Bushing Failure...
  237. Flywheel problem - still not fixed!
  238. Fuel Guage not registering level
  239. tinted window noise fix
  240. help - advice on manual transmission problem
  241. Wierd pump/motor/something sound when car is off
  242. Rear electric hatch problems - moisture related
  243. multiple codes on cyl 3
  244. Xenon lamps flicker when I go over bumps
  245. Misfiring
  246. Rain Sensor Install?
  247. Hit a bump, Glove box opens
  248. Ruined my SUPERCHARGER!!
  249. Change hood release cables
  250. Wanted: Mini (not S) with bad engine or CVT
