Engine Leaking Oil !!!
Old May 18, 2007 | 04:38 AM
ViVi^BoY's Avatar
ViVi^BoY
hi... anyone experienced this problem ?!!?!? oil leaking from engine.
Old May 18, 2007 | 04:48 AM
daflake's Avatar
daflake
Only once before and I had it repaired. Oh course it was my Ford and hear that it is pretty normal for them.
Where, what and or how would be nice.
Old May 18, 2007 | 04:53 AM
DPCooperS's Avatar
DPCooperS
How much oil, and was your oil changed recently??
Old May 18, 2007 | 08:51 AM
thulchatt's Avatar
thulchatt
if it is not much it could be the pan gasket.
There is a thread on this. I had the gasket changed on my 04 because of a drip every couple of days.
Old May 18, 2007 | 10:37 AM
sfjames2's Avatar
sfjames2
unless its actually running down the side of the engine or you see a puddle anywhere I wouldn't worry. If you want to clean that area up, go buy a valve cover gasket and replace the old one. Clean the area prior to installing the new gasket of course.
I did have this issue about 3years ago while still under warranty, been fine ever since.
Old May 18, 2007 | 07:52 PM
hotjanitors2's Avatar
hotjanitors2
I had this happen to me right after I changed my oil. My filter wasnt all the way on there though. I dropped about a quart and a half of oil.
Old May 18, 2007 | 09:16 PM
ViVi^BoY's Avatar
ViVi^BoY
yesterday i changed engine oil, me and my technician found it. it actually dried. But my technician check the screw, every each one them very tight, we wonder why there is engine leak.. :(
is that gasket problem ?
Etrain
16
Aug 5, 2024 04:37 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
