Is it from the A/C ??
Old Apr 27, 2007 | 02:02 AM
harhoosh's Avatar
harhoosh
hi guyz..
I dunno wuts the problems exactly.. once i open the A/C the RPM goes up . and this make me sick . is it from the compresor ? or sumthing relateted to somthing eles
Old Apr 27, 2007 | 02:55 AM
BFG9000's Avatar
BFG9000
It's the computer, which was intentionally programmed to crack the electronic throttle whenever a load like A/C or power steering is switched on, since otherwise the engine may stall more easily (for example, if the compressor cycles on right as you are releasing the clutch).
It's been virtually a standard feature since air conditioning was first put into cars in 1939, first with a "fast idle" dashpot on the carburetor, then later with various idle air controller motor schemes. With e-throttle no additional hardware is required, only software.
Old Apr 27, 2007 | 03:14 AM
harhoosh's Avatar
harhoosh
so wuts the solution now ??
Old Apr 27, 2007 | 06:33 AM
jibeho's Avatar
jibeho
Don't use your A/C
Old Apr 27, 2007 | 06:53 AM
Loony2N's Avatar
Loony2N
What makes you think it is a problem and that a "solution" is required? It's designed to keep the engine running smooth and eliminate stalling.
Old Apr 27, 2007 | 06:56 AM
Loony2N's Avatar
Loony2N
BTW, maybe you can help me out. What is the purpose of purposely misspelling words?
Old Apr 27, 2007 | 07:51 AM
BFG9000's Avatar
BFG9000
harhoosh is in Bahrain, which is probably not the easiest place to obtain MINI service, and is hot.
In the old days you could simply adjust the dashpot until you were happy (or unplug wires from the PS pump or A/C compressor), but now you'd need a custom software flash (MTH?) which I probably wouldn't recommend for a JCW. Let's face it: a car with the early gear ratios and driven in such heat with A/C on is going to feel pretty soggy on the bottom end anyway and decreasing the idle speed will likely make it even worse.
Old Apr 27, 2007 | 03:59 PM
harhoosh's Avatar
harhoosh
I think i've to use with this : (
Old Apr 27, 2007 | 06:16 PM
nixjosh2's Avatar
nixjosh2
give him a break, english is not his first language
Old Apr 28, 2007 | 01:33 AM
harhoosh's Avatar
harhoosh
listen guys... i know that my english is soo bad.. cuz im persian .. and i live in bahrain.. my 1st language is Arabic,, so sorry for my grammer and my spelling mistakes
Old Apr 28, 2007 | 04:25 AM
MiniTron's Avatar
MiniTron
Don't worry about it Harhoosh. There are many Americans around here that hardly type any better than you.
I've been to Bahrain, and the English there takes some getting used to. Don't let anyone scare you away from asking questions.
Old Apr 28, 2007 | 06:57 AM
buzzsaw's Avatar
buzzsaw
I too have been to Bahrain while flying a Beechcraft Starship to Singapore. It was one of the best refueling stops on the trip. We were treated very well. Your English is just fine.
Old Apr 28, 2007 | 09:06 PM
harhoosh's Avatar
harhoosh
Thanks guys :$
YOU WELCOME TO BAHRAIN : )
GAT
Oct 21, 2015 02:12 PM
Brochacho
Sep 29, 2015 10:24 AM
Nicefeet
Sep 27, 2015 11:14 AM
dragonby
Sep 25, 2015 08:10 PM
bneer
Sep 20, 2015 11:29 AM
