Drivers side window squeal
Old Apr 25, 2007 | 11:22 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
When I put down my drivers side window it squeeks, squawks, and squeels almost all the way down. I have put the windows down every day since I bought it in August and it just started squeeking today. Is there anywhere that I can lube up by removing the door panel to stop the awful screech?
(I described the sound as a squeek, squak, squeel, and screech I need to make up my mind what I want to call it )
Old Apr 25, 2007 | 11:46 AM
techtipz's Avatar
techtipz
sent PM. Do not know how to find threads after I reply.
Old Apr 25, 2007 | 11:50 AM
roggenmini's Avatar
roggenmini
I have had the same problem. Turns out the Seal was dirty. Cleaned it and the squeek went away!
Old Apr 25, 2007 | 11:51 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Did you have to pop the door panel off for that? Or what all did that involve?
Old Apr 25, 2007 | 12:10 PM
Edward_Teach's Avatar
Edward_Teach
I have noticed that the inside of the window seal tends to pop inward and needs fishing out from time to time. That could be the cause of your squeek.
Old Apr 27, 2007 | 10:37 AM
asundaralingam's Avatar
asundaralingam
I had the same problem with mine. involves removing the door panel and lubing the two guides on either sides.
Old Apr 29, 2007 | 03:44 AM
lvbltec's Avatar
lvbltec
mini has a measure in place to fix the noise in the windows bring it to the dealer if your unsure how to fix it
Old Apr 30, 2007 | 01:04 PM
hemiheaded18's Avatar
hemiheaded18
My window does it sometimes only going up. If I clean it and wipe the track or if it's raining, it won't do it. Try spraying glass cleaner on a thin rag and wiping into the track.
woodstudio
Mar 15, 2020 08:28 AM
RACEnSK8
Aug 31, 2015 01:08 PM
Russter500
Aug 26, 2015 12:11 PM
StuRat
Aug 25, 2015 05:27 AM
messyjesse96
Aug 12, 2015 05:51 AM
