cooling fan
Old Mar 7, 2007 | 01:21 PM
phillyunderworld's Avatar
phillyunderworld
cooling fan
why the hell is my cooling fan still coming on? it's like 16 degrees out. i swear it never used to do this before i had my a/c fixed this summer.i never recall the cooling fan coming on in the cold weather like this before. not only once in awhile either . very frequently i might add.any ideas? or is this normal?
Old Mar 7, 2007 | 01:48 PM
kapps's Avatar
kapps
Do you have the A/C on to keep things from fogging up? The fan will run pretty much all the time if the A/C is on, even if it is blowing heat. Also, check the coolant level.
Old Mar 7, 2007 | 02:32 PM
ijcwmc40's Avatar
ijcwmc40
Mine kept cycling about every 10 seconds. Dealer explained that fan has two stages. Stage 1 was inoperative, so it caused stage 2(much loader than 1) to operate - which led me to notice the frequent operation. They replaced it under warranty - hope this helps!
Old Mar 7, 2007 | 02:35 PM
phillyunderworld
that makes sense, thanks
PsychoRallye
21
Feb 17, 2019 06:08 AM
monkiboy
Oct 16, 2015 09:58 AM
kevinlhr310
Sep 27, 2015 02:31 PM
rt808
Sep 25, 2015 01:59 PM
