Motor Mount removal and replacement
Posted this question in the 2nd gen forum, oops, I still think of the Mini as the 1st gen. Anyhow:
We have an '03 MCS with 120,000 miles. The passenger side motor mount needs replacing. We received the replacement from the dealer and are now trying to remove the old one. It appears that it needs to be unscrewed from a stud on the frame rail, can anyone verify that? Any tips on how to remove it?
Bob
Bob
I’ve never removed it but I can show the parts picture http://www.realoem.com/bmw/showparts...66&hg=22&fg=05 and a picture of the Torx (E, I don’t know the size) head; it is the silver bolt on the far right. It can be reached by removing the fender liner.
Lisle makes and inexpensive set of Torx E sockets (Sears and auto parts stores) which would be a worthwhile addition to the MINI tool kit. I’ve used my set on the door brake and clutch pressure plate so with any kind of mileage on the vehicle they won’t be a wasted purchase.
A TSW engine damper, installed over the stock engine damper, should extend its life as it takes a good deal of the stress off of it. I had the stock engine damper replaced once already inside of 20k miles, under warranty. And the TSW firms up the connectedness of the driving experience. Smooth up and down shifting is easier.
Zip
Zip
Zip
Zip
Without knowing the grade of the bolt or thread pitch I will take a guess at 41 ft-lb because it's an M10 bolt on the chassis and that is a common value. If it has the grade stamped on the bolt then determine the pitch and look it up to be sure.
Page 010-8 in the Bentley Service Manual has a table for torque values and bolt grades. It shows an M10 with a 10.9 metric grade at 66Nm which converts to 48.7 lbf-ft.
I'm a little suprised it's an M10; I was expecting an M12 at 74 ft-lb.
Steve
That's a perfectly good question.
Although I am generally price-driven, there are times when other factors override $$. I like the mounting design and location of the TSW better than the LOTR damper. To me, the TSW appears to be more functional in its workings and adjustability. A couple of the guys in my club tried both brands and decided the TSW was functionally (and aesthetically, if that's important to you) superior. After seeing both of them, I have to agree. Most of the guys in my club that have engine dampers have the TSW. And most of us are not rich.
Also, I didn't think the difference in price outweighed the differences in functionality I have outlined. To me, a little over a hundred bucks was a reasonable price for a device such as this. I didn't feel that the reduction in price of the LOTR unit was worth what I would not be getting. Would I have liked the TSW unit to be less expensive? Sure, but I'd like everything to be less expensive.
Does all this mean that the TSW is wonderful and the LOTR is crap? No, of course not. My views on the engine dampers are my views (and the views of most of the guys in my club, who have a lot more insight into these cars than I do).
Buy what you will. Spend what you want. The goal is to be happy. I'm happy.
Zip
Zip
silence2-38554
Nov 12, 2015 09:39 AM
JPMontes3
Aug 23, 2015 01:26 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
minipopkart
Aug 13, 2015 05:22 AM
