Strange (but very fun) problem...
Old May 16, 2007 | 02:39 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Hi motorers,
For a few days now, whenever I take a curly a bit "faster", the rear-end loses grip very quickly and sends me into a little drift.
The first time it happened, it was surprising, but now it's fun. But, I would like to know what to check under the car to solve this problem... It is very fun, but my car does not handle as well as it used to be...
I have a 19mm rear swaybar (a fully adjustable one with the links) & H&R springs.
What do you guys think I should look first?
thanks!
Old May 16, 2007 | 04:12 PM
Rawhyde's Avatar
Rawhyde
A stiffer than stock rear swaybar will give some oversteer if you let off the throttle in mid-corner. Is the bar new? Did you put it in a stiffer setting? Are you driving harder and/or with a different technique? What has changed recently?
If you've not made any changes and the cornering limits are lower and oversteer prone, check the front swaybar endlinks and make sure one isn't broken.
Rawhyde
Old May 16, 2007 | 04:18 PM
chows4us's Avatar
chows4us
Agreed. It sounds like oversteer if the rear end wants to come around. Have you changed the tires? If so, they may be less sticky.
Old May 16, 2007 | 06:15 PM
DarkMiniCooperS
That's what is strange... I didn't change any setting or parts regarding the suspension in the last 9-10 months... I've had that swaybar for a year now. And my tires are not that bad either (Falken FK452) and only a few months old.
I sure will have a look at those front swaybar endlinks!
Old May 16, 2007 | 06:24 PM
Motor On's Avatar
Motor On
PRessures and if your driving style has changed.
Old May 16, 2007 | 06:36 PM
sonichris's Avatar
sonichris
maybe check if your front links are still ok... less front bar will do this too.
Old May 17, 2007 | 11:37 AM
03BRG's Avatar
03BRG
Does it only do it on a right or left turn? if the end links are ok maybe a bent sway bar
Old May 17, 2007 | 11:56 AM
DarkMiniCooperS
It does it mostly on right turns...
PsychoRallye
21
Feb 17, 2019 06:08 AM
USA-RET
Oct 27, 2015 10:42 AM
eMINI of the State
Oct 2, 2015 03:12 PM
pkillur
Sep 30, 2015 10:51 AM
