PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. OBDII problems... need help please
  2. any supercharger wastegate problems
  3. Warranty tires????
  4. new clutch at 25k!
  5. wheel removal help?...
  6. Dealer Maintenance Question
  7. Extreme MPG
  8. Speedo/gas/temp needles vibrate at start up
  9. Radiator Hose Clamp Tool
  10. Adjust clutch to be lighter?
  11. Belt Issue
  12. testing ethanol content ...
  13. oil questions
  14. Replace power steering pump
  15. Changing oil tomorrow, what weight?
  16. Speaking of Power Steering
  17. Anyone had THIS issue?
  18. Supercharger Whine
  19. Any Lift Recommendations?
  20. Service Engine Soon light keeps coming back on
  21. Sinking clutch pedal & Cant Get it in to gear?!?!?
  22. Can new front wheel bearings be pressed in?
  23. OBD code anyone?
  24. Yipee for cool weather and Redline SI-1!
  25. crackling sound on MCSa
  26. Parking light / Turn signals
  27. THUMP when door locks go down?
  28. How to remove air duct from box?
  29. Limited slip differential: Lifespan And DSC effect
  30. 2nd Mod complete: What's behind the airbox mod? (bmp)
  31. Clicking Sound When Breaking...
  32. Polyurethan Motor Mounts or Engine Torque Brace?
  33. oil canister flat spot
  34. Dirty chrome exhaust pipe tips
  35. Need Help - MINI Service
  36. ECU re-flash. Damn!
  37. Texas Speedwerks & LOTF Torque Dampers - help!
  38. Reoccuring issue with xenon headlights, need your help!
  39. hood/bonnet light won't go out
  40. Leaking motor mounts? Anyone else?
  41. EML light comes on & loss of power
  42. 12V Power outlets: constant on, possible?
  43. Engine Oil Analysis Service
  44. Question about Xenon Headlights
  45. Two things???
  46. Seat help, and door locks
  47. Oil Filter Housing
  48. Loose Throttle Cable?
  49. What occurs at the 10,000 mile service?
  50. Battery Dead. How long to run to recharge?
  51. Where can I find radiator grill for 02 MC?
  52. 2nd gear
  53. Help identify part that needs replacing and where to buy
  54. Help!!! did my radiator blow or what???
  55. Service Bulletins-where can I find them?
  56. help with code troubleshooting
  57. help with code troubleshooting
  58. That's a Light Clutch
  59. Crunch going to reverse
  60. Clunk when engaging gear...
  61. Squaky Clutch?
  62. Engine codes definition needed
  63. Service Bulletin Question? SI M 21 01 05
  64. Glovebox liner replaced... No more a/c vent?
  65. Downshift clunk/jerk?
  66. Headlights NOT moving anymore!?
  67. Supercharger Problems !
  68. Steering Loss/Lights Flicker--Connection?
  69. Going in for 1st Service in a couple of hours
  70. Massive Oil Leak
  71. Some new BS
  72. Broken Driver Seat?
  73. Doors Locking Themselves
  74. Busted Motor Mount
  75. Can Bad Gas Do This??
  76. Clock Light/Fuel Gauge Flicker?
  77. Where is the fresh air intake for the a/c?
  78. Intermittent Screech/Squeal at 70MPH?
  79. Turn signal gone wacky
  80. Shift rod wobble about quater of an inch with SSK
  81. Blown Transmission
  82. Help finding part or repair
  83. What to check when the power steering goes away?
  84. ****ing monkeys
  85. Valve cover leak
  86. Engine Flush?
  87. weather strip/seal wear - normal?
  88. totally dead 2003 MCS
  89. Service Warranty is Over!
  90. Loss of Power After Engine Cool Down
  91. OEM Plugs at 60K miles
  92. Xenon went purple?
  93. Questions about Xenons
  94. Do modded cars run perfect?
  95. '04 MCS - Alternator & Belt questions
  96. Could use some help from Engine guys!
  97. Can anyone tell me...?
  98. External temp. sensor broken
  99. what IS that?
  100. Loose switches (window, lock)... how do I fix
  101. Denso IK22
  102. OBD II Connector Not Functioning
  103. Slight hiss when I shift
  104. Help replacing window motors/regulators
  105. Thunk, underneath car, from abrupt bumps
  106. intermittent windows
  107. MC (non-s): engine idle ticking
  108. Problem with Negative Battery Connection
  109. Whoops. Xenon problem
  110. White residue, soapy feeling under the hood...
  111. P0340 Fault Code
  112. broken 05 engine mount???
  113. Another "Quirk", Another Headache :(
  114. 911 help engine ratel ?
  115. Radiator hose length?
  116. M7 SRP owners experience
  117. MINI Keys
  118. Click or Dbl Click When shifting from 1st to 2nd Gear???
  119. Newbe oil change
  120. Extended Warranty Pitfalls?
  121. Installing Cruise if you dont have it stock
  122. Alignment needed or not?
  123. clean out that rodent nest!
  124. Serious Transmission Problem - Urgent Advice !
  125. Stainless overflow tank on a Cooper?
  126. DSC, tire inflation and ABS lights on...out of nowhere.
  127. windshield wiper replacement
  128. Switch box harness plug. how do you unlatch?
  129. Bleeding the Clutch
  130. JCW Air Filter Maintenance
  131. Slight hesitation - engine map?
  132. In need of a picture of MCS exhaust mounting
  133. Super-fast blinker mode!
  134. Warranty Legal Upgrades
  135. Motor Mount Damage
  136. coolant preferences?
  137. Oil Filter canister stuck
  138. Flywheel warranty fix
  139. Lost on door panel removal.
  140. not BENEATH the bonnet, more like part of the bonnet...now I need...
  141. OBD II code
  142. Help - Warranty Claim
  143. question about wipers....
  144. Micro filter replacement
  145. New to the Mini - Do It Yourself
  146. Castrol OUT, MOBIL 1 In, encore...
  147. Poll: Mushrooming/strut mount failure data collection
  148. 100 octane...good or bad for a mcs?
  149. A/C doesn't cool down car on hot days
  150. Mechanic
  151. stock tires lose pressure
  152. Burnt Clutch Smell
  153. back pressure while accelerating
  154. Did I just lose my clutch or my transmission?
  155. M7 Strut Bar install suggestion (insulation pad surgery)
  156. Flywheel... new and improved.. I hope
  157. Dealer refuses to replace Bypass Valve under Warranty.
  158. Is a locked door stronger?
  159. Black fluid leaking!
  160. Erratic MSCa downshifting on its own.
  161. M7 Strut Reinforcement Plate Problems?
  162. Help my car sounds like rubbing when I make slow tight turns
  163. Can you buy an extended warranty anywhere?
  164. Engine details
  165. i dropped my nut
  166. Mini Cooper Cylinder Head
  167. wiring harness in battery box problems
  168. Too much Ethanol in current gas causing problems...
  169. Possible transmission problems?
  170. need some quick help - oil spilt in engine bay
  171. Need HELP with S intake manifold removal..
  172. No tailgate cable under the rear seat
  173. Most Miles/Kms on a MINI?
  174. CAI cut-out template???
  175. Excessive Power Steering Noise
  176. Installed the 2% crank pulley, what's next?
  177. Factory Reset Tool
  178. How long does a Mini Engine....?
  179. Fault Code P0563
  180. When are brakes normally serviced?
  181. I must have caught a MINI virus...
  182. spark plugs
  183. 02 mini OBD?
  184. Mini Service Manual...Best one
  185. 100 miles before 36K. Do extended warranty or not?
  186. Is the "Inspection II" required???
  187. How to tell if O2 Sensor is bad?
  188. Recommended brake pads
  189. Looking for a reliable shop near Knoxville, TN to install 2% crank pulley...
  190. 2003 MC-ECU and Engine revisions
  191. First Service Advice
  192. what does the P0030 P-CODE DO?
  193. Need Dinan advice, please...(some what long)
  194. Should I remove my CAI?
  195. 218 Hp.
  196. Ses light and p0444 code after pully install
  197. DSC Warning Light
  198. Gas Gauge Issue?
  199. Need Help with 05 S (interesting)
  200. Muffler Hanger Rusted and Broke
  201. Hot Ignition Key after Use?
  202. Timing chain or belt, Valve adjustment?
  203. type of oil
  204. Induction Downtube
  205. Dead Battery on the Road Question
  206. Downshifting concern
  207. Removing Cabin Air Intake Grill
  208. Oil Catch Can? Mmmmm....I'm not so sure....
  209. Calling all higher-mileage MCSa (automatics)
  210. m7 throttle body
  211. Messed up shifting
  212. How to adjust headlights
  213. "S" Hesitates When Shifting
  214. Mini Service In Seattle?
  215. Idle Issues With P0507 Code
  216. put put put... pff this sucks!
  217. Cabrio Boot Switch Problems
  218. CEL and EML light after catch can install...
  219. qualified shops near York, PA
  220. Power Steering Pump?
  221. Detroit Tuning BPV; What is it and what will it do for me?
  222. S.o.s. My S.e.s. Light Is On
  223. Time to do Inspection 1
  224. What is the 2nd Inspection comprised of???
  225. List of Fault Codes?
  226. Belt Number
  227. Front upper strut bolt sheared off....crap!!
  228. Air Compressor for Mini A/C
  229. K @ N Typhoon Ram Air
  230. Yet another "noise" question. Can it be the CAT?
  231. New '06 MC at 1500 miles cut at stop light
  232. Where to get metal trash cans for combustibles?
  233. Can we wetsand our headlights?
  234. Advice needed: Grinding noises when idling...
  235. Rear brakes gone again..fronts still good?!?
  236. Noise in belt system
  237. bonnet smashed
  238. What Is This Leaky Part Under My Hood?
  239. Power Steering issues!
  240. Synthetic transmission fluid ok? (Redline, Royal Purple?)
  241. uneven front strut towers
  242. Valve Cover Gasket Leak
  243. Help diagnosing the noise.
  244. Need help with SAFC 2
  245. Software to read OBDII Codes
  246. Metal grindings in my differential - is it normal?
  247. Brake Pad Question...
  248. ABS + wheel speed sensor when DSC turned off?
  249. passenger seat puckers
  250. Almost 50,000
