Factory Reset Tool
Old Sep 1, 2006 | 09:57 AM
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
Factory Reset Tool
MIB is racking on the miles quite quickly. Most likely 25K before it is a year old. Even with the extended warenty... It is gonna get costly quick!
Is there a place that sells the factory reset tools. They will re-set the change oil and factory service lamps. I have seen them in AutoWeek for BMW but never for MINI's... That is untill MIB had its oil changed at Bill Jacobs MINI. There was an add in Roundel (BMW magazine sp?) but I have never seen the NAM vendors have them.
Anyone have a lead?
Old Sep 1, 2006 | 10:06 AM
Dr Obnxs's Avatar
Dr Obnxs
you don't need a tool to reset the service indicator...
when I have a bit more time I'll dig up the procedure...
Matt
Old Sep 1, 2006 | 10:09 AM
gizzer777's Avatar
gizzer777
You do not need a tool!
This is from an 03 procedure...probably the same for almost all!
Maintenance Required Lamp/Indicator: Service and Repair
RESETTING the Service Interval Indicator[/FONT]
The II can be reset using the trip odometer reset button in the instrument cluster:
The ignition key must be in the “0” (off) position.[/FONT]
Press and hold the trip odometer reset button in the instrument cluster, and turn the ignition key to the “I’ (accessory) position.
Keep the button pressed for approx. 5 more seconds until the current SIl status appears in the display: “Oil Service” or “Inspection” Release the button.
Press the button again and hold for approximately 5 seconds to change to the reset mode. The letters “RST” appear. While the display is flashing press the button briefly to reset the Service Interval. The new intervall will be displayed for 5 seconds.
Release the button and turn ignition off.
Old Sep 1, 2006 | 10:44 AM
Dr Obnxs's Avatar
Dr Obnxs
Thaks Gizzer...
saved me some time searching...
Matt
Old Sep 1, 2006 | 11:17 AM
gizzer777's Avatar
gizzer777
My Pleasure...
Matt
A Pleasure Matt:
Lots of folks here helped me when i needed it too! (most of the time)
I save all my info that i find on the mini in a directory on my HD and on cd re-writeables!
Old Sep 1, 2006 | 11:26 AM
Tom D's Avatar
Tom D
http://www.peakeresearch.com/
Old Sep 1, 2006 | 11:42 AM
BE4TNUT's Avatar
BE4TNUT
Now how do you do it if you have the factory NAV?
BEATNUT
Old Sep 1, 2006 | 12:08 PM
Dr Obnxs's Avatar
Dr Obnxs
Exactly the same...
BEATNUT
it's the button on the speedo by the odometer.
Matt
Old Sep 1, 2006 | 01:58 PM
Fatherdeth's Avatar
Fatherdeth
I bought mine from.......
www.bimmerworld.com
It's a Peake product as someone mentioned above, but the cost is a little cheaper.
molala
Oct 2, 2015 01:53 PM
The_Kid
Sep 14, 2015 03:41 PM
Sep 3, 2015 10:45 AM
Sep 2, 2015 09:05 AM
