M7 Strut Bar install suggestion (insulation pad surgery)
Old Sep 6, 2006 | 04:17 PM
AntiqueCarNut's Avatar
AntiqueCarNut
I bought an M7 Strut Bar (STB) last week. The install is straight-forward. MINI, somehow, makes no accomodation for the strut bar (not even the JCW version) on the under-bonnet insulation pad (IP). The M7 STB's height causes the back of the bonnet to be pushed up.
It was suggested that I thoroughly soak the contact area of the STB to IP by spraying distilled water from a plastic spray bottle. Then I should place plastic over the STB and close the bonnet. This, in theory, would compress the IP sufficiently to permit the bonnet to close completely. Well, this didn't work for me. The cotton felt of the IP is very dense and the fabric that covers the IP seems to resist the penetration of the water, to a great extent.
Peter at M7 suggested that I remove the IP and using a utility knife, cut the black cover material on the back of the IP - along the impression lines that the STB made, and remove the compressed cotton insulation in the area of the STB via the slits the rear of the pad. I made two parallel slits - about 2.5' apart, along the area where the STB contacts the IP. I pulled the cotton felt out of the IP by hand and also using a needle-nose plier where the material is very compressed. I set the IP over the engine compartment and could then feel where I needed to remove more insulation, by pressing the IP to the STB.
After a few test bonnet closings, I used heavy black duct tape to mend the slits on the back of the IP, and then re-installed the IP to the underside of the bonnet. VOILA! This worked great. The IP looks untouched and the bonnet closes properly, now.
Old Sep 6, 2006 | 05:32 PM
SpunkytheTuna's Avatar
SpunkytheTuna
I took my underhood pad off and tossed it into the garage about eight months or a year ago.
Nothing bad's happened as a result.
Old Sep 6, 2006 | 06:04 PM
Crashton's Avatar
Crashton
I'm glad to hear you've worked it out to your satisfaction. I did the soak & slam. It helped a lot, but it's not perfect. I've grown used to it & now I don't even notice it.
Old Sep 7, 2006 | 11:39 AM
rubyred3's Avatar
rubyred3
haven't there been reports of paint on the bonnet discoloring with this pad removed?
Old Sep 7, 2006 | 03:16 PM
Crashton's Avatar
Crashton
I've not heard of one case. I believe the reason the pad is there is to act as a sound deadener. There isn't enough heat to discolor the paint. If there is your car is probably on fire.
Old Sep 7, 2006 | 03:25 PM
goaljnky's Avatar
goaljnky
Glad it worked for you. I went the JCW bar way and had no problems, nor a need to remove anything. It was more expensive.
Old Sep 8, 2006 | 12:04 AM
El_Jefe's Avatar
El_Jefe
over time, that sort of heat can kill your paint. if you drive it right.
Old Sep 8, 2006 | 02:03 PM
Crashton's Avatar
Crashton
Sorry, but I don't buy that. I've had lots of cars without anything under the hood & have never had paint issues. Guess I just can't drive right.
Old Sep 20, 2006 | 07:37 AM
MirthScout's Avatar
MirthScout
AntiqueCarNut, how did you reinstall the insulation pad? How does it attach?
Old Sep 20, 2006 | 02:23 PM
Crashton's Avatar
Crashton
There are little plastic doodads that hold it to the hood. If you take a look under the bonnet they are easy to see. The pad is very easy to remove & reinstall.
Old Sep 20, 2006 | 03:10 PM
agranger's Avatar
agranger
I helped with an install of a upper strut tower bar a few months ago. Once the bar was in place, I covered the top of it with baby powder and gently closed the bonnet. When we opened the bonnet, we could easily see where contact was made and we trimmed away bits of the liner until the fit was right and no more powder was transferred.
Old Sep 20, 2006 | 04:39 PM
kenchan's Avatar
kenchan
i would also probably just remove the pad rather than cutting it.
Old Sep 20, 2006 | 04:40 PM
Crashton's Avatar
Crashton
Now that's a great tip.
Old Sep 20, 2006 | 04:45 PM
Crashton's Avatar
Crashton
I pulled the pad on mine when I first installed the bar. At least on my car much of the area under the pad wasn't painted with body color. Just an ugly primer. That is why I put the pad back on & did the soak & slam.
Old Oct 4, 2006 | 07:49 PM
Gromit801's Avatar
Gromit801
I might think about using chalk on the bar to leave the mark. No chance of spilled talcum in the engine bay.
squawSkiBum
Oct 2, 2015 09:21 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
