OBD II code
Old Sep 9, 2006 | 04:39 PM
TUFFMINI's Avatar
TUFFMINI
OBD II code
Hello,
have two codes on my car since I installed a 59mm throttle body.
P1498 and P1689
My service Manual does not tell me what they are and even the Auto Zone guy could not tell me even after he ran his OBD II check.
Anyone have a clue?
thanks,
Kev
Old Sep 9, 2006 | 04:50 PM
Kendel72's Avatar
Kendel72
The dealer told me yesterday that my P1498 was from unmetered air, I installed an AGS and the dealer said that the SC tube was not sealing off @ the SC!
Old Sep 9, 2006 | 05:01 PM
Rick-Anderson's Avatar
Rick-Anderson
P1689 (same as MINI-FC code 5769)-- Electric throtle control monitor level 2/3 torque calculation error
StarLord's Avatar
StarLord
maybe OBD-II codes
I googled it and came up with these..
This site lists the BMW OBD-II codes, but your 2 weren't listed:
http://www.obd-codes.com/trouble_codes/bmw/index.php
I found them here (though not BMW/MINI specificaly):
http://autorepair.about.com/cs/troub...l_obd_main.htm
P1498 Voltage Problem In EGR Valve Position Sensor Circuit
P1498 High speed Rad Fan Ground CTRL Rly Circuit
P1689 Traction Control Delivered Torque Output Circuit
Hope that helps..
Old Sep 9, 2006 | 05:13 PM
Rick-Anderson
P1498 is an Auxiliary Emissions Control problem
Old Sep 9, 2006 | 05:27 PM
TUFFMINI's Avatar
TUFFMINI
not a MINI code??!!!
I found the codes you listed but they are for GM or ford vehicles. MINI info is not well published.
thanks for all the help, it sound like Kendel72 and Rick-A nailed it.
I installed the M7 throttle body 59mm when i started getting this issue. when i put the stock back on the issue is resolved.
will need to speak with M7 again if my next step does not correct the issue. i purchased the MTH package stage 1 with hopes that this will correct the TB delima.
thanks much gang!
Hope that helps..
Old Sep 9, 2006 | 07:48 PM
Kendel72's Avatar
Kendel72
Bingo!! I am going to have to tear my front end off to figure out where on the AGS I am getting the air leak, the tech @ hendrick said it sounded like the back of the supercharger and that the gasket for the SC tube is easy to get a leak on.
thadscottmoore
Jun 4, 2021 07:19 AM
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
RocketUSA
Sep 15, 2015 07:45 AM
mtwaddle
Sep 13, 2015 08:10 PM
