Another "Quirk", Another Headache :(
Old Sep 17, 2006 | 03:04 PM
Motor On's Avatar
Motor On
Sidebar:I recently dicided to remove the VGS and I noticed the developments of tons of tiny bubbles on the coating in the IC, should I be worried?
The BIG Issue:mad:mad:
The TB has been fluttering at 2800-3200 RPM on its own recently (2 weeks, steady throttle on starts and steady highway driving w/ and w/out cruise control), reason for removing VGS, could be connected? I removed the VGS thinking the TB could be fluttering from a vacum leak somewhere, and having that mess around witht he sensor. After removing the VGS the fluttering became far more pronounced and frequent and happens almost every time I'm in the 2500-3500. RPM range
After removing the VGS and reinstalling the IC I figured I'd check to see if there were any codes, and I got 2
Code P0123 : TPS/ Pedal Position Sensor A Circuit High Input
Code P0222 : TPS/ Pedal Position Sensor/ Switch B Circuit Low Input
But no SES light.
Mods thus far are Alta CAI w/hose and the Removed VGS.
Anyone have any ideas?
Old Sep 17, 2006 | 04:57 PM
DAVESTER's Avatar
DAVESTER
warranty
You have a 50,000 mile warranty or four years
Old Sep 17, 2006 | 05:23 PM
Motor On's Avatar
Motor On
For multiple unrelated reasons, I'd like to avoid that route unless part replacement is going to be my only solution.
Old Sep 17, 2006 | 07:24 PM
joey1320's Avatar
joey1320
the fluttering could be cause by a faulty sensor in the accelerator pedal not sending the right voltage to the DME. plus since you have the 2 codes for the accelerator/throttle sensors i would say you may need a new pedal assembly.
Pyrs
R55 :: Clubman Talk (2008+)
19
Sep 8, 2015 01:43 PM
h0micide
Aug 25, 2015 12:19 PM
reggie1
30
Dec 1, 2003 07:50 AM
