oil questions
Old Oct 12, 2006 | 04:17 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
oil questions
i know that minis use the high grade synthetic stuff good for 15k miles. however, could you use some regular synthetic oil? what about natural oil?
one more thing, the next oil change will be the first one with my oil cooler attached. it seems this would trap alot of the old oil. but once new oil is added, this would all mix in. so i am guessing that the same weight oil is needed and that the old oil that was left in the cooler wont hurt the car, right?
Old Oct 12, 2006 | 04:29 PM
Eric_Rowland's Avatar
Eric_Rowland
'regular synthetic'?? I'd recommend using a high quality synthetic. You CAN use dino oil, but you forego the benefits of sythetics - longer life, better lubricating properties. Why spend $20K+ on a car and cheap out on $20 per oil change?
You definitely want to use the same weight oil. The old oil (in the cooler) will be dirty. It would be best to poor this out. Otherwise, reduce your oil change interval to account for X% of dirty oil in your clean oil.
Old Oct 12, 2006 | 05:47 PM
kenchan's Avatar
kenchan
walmart sells those Mobil1 5 quart jugs for like $25...
Old Oct 12, 2006 | 05:48 PM
DrkSilvrMini's Avatar
DrkSilvrMini
Mobile 1 baby
thats what i was putting in mine.
Old Oct 13, 2006 | 05:59 PM
herbie hind's Avatar
herbie hind
i'm running a cooler too . i'm gonna put a drain on it . it's one reason i bet alot of guys running coolers go top mount.
silence2-38554
Nov 12, 2015 09:39 AM
patpatpat
Aug 27, 2015 07:51 AM
ShadyCoop
Aug 24, 2015 06:05 AM
elightbo
Aug 17, 2015 01:50 PM
Emnotek
Aug 13, 2015 05:47 PM
