what does the P0030 P-CODE DO?
Old Aug 28, 2006 | 09:00 PM
redrunner2's Avatar
redrunner2
I have pulled this code recently, and I have tried to find the solution. On my code reader it said P0030 HO2S heater control circuit ( bank 1 sensor 1). I had some exhaust problems due to a trashed flex joint on my header, but it has been fixed since then. I erased the codes, but after I drive the car, and then restart it the engine light comes back on. Could the first O2 sensor be faulty? If someone could help me I would appreciate it.
redrunner2
Old Aug 29, 2006 | 06:52 AM
Jdewey's Avatar
Jdewey
HO2S Heater control Circuit open.
The Heated Oxygen Sensor is not heating. S may mean the Secondary sensor which is after the cat. If you had exhaust problems, you may have a damaged wiring harness leading to the O2 sensor.
John
Old Aug 29, 2006 | 08:01 AM
redrunner2's Avatar
redrunner2
Thanks, I did replace the 02 sensor, but not the harness. That might be the problem. thankyou
Old Aug 29, 2006 | 08:08 AM
inimmini's Avatar
inimmini
I think sensor 1 is the upstream one. Check to make sure the sensor & wires are not squished up against the heat shield. This happened to me with the OBX header, and the O2 sensor thinks it can't heat up. Bending the heat shield fixed the prob. At least some aftermarket headers put the O2 sensor in a slightly different location than stock.
Old Aug 3, 2008 | 02:12 PM
Haggardsk8er's Avatar
Haggardsk8er
Thread renew!!!
So this code is for the precat or post cat sensor?
Old Sep 15, 2013 | 09:55 AM
ACallahan's Avatar
ACallahan
I love being able to search old posts. Bingo!! this was my exact problem was just getting rdy to buy a new sensor.
Old Dec 14, 2013 | 04:02 AM
RA082324's Avatar
RA082324
Started with 3 codes. One for evap purge valve. Replaced that. Then got one for bank 1 o2 sensor. Replaced that with the proper NTK factory sensor. Made sure all wires are in safe spots. Now getting p0030. Not sure why if the sensor and wiring is all brand new. Is this normal? Is there some sort of break in period on a new o2 sensor?
Old Dec 15, 2013 | 12:11 PM
RA082324's Avatar
RA082324
so after some testing, i am still looking for some assistance/amswers, but have found the following:
- it doesnt matter if the engine is hot or cold. the light and p0030 code come on immdiately every time i start the car, unless the code is clearly just before starting. for instance, if i clear the code, start the car, the light remains off. as soon as the car is turned off, the next time it is started, the code and light are back upon starting.
- ive ruled out a faulty sensor since no other codes are being displayed and the car is running smoother than ever.
- could it possibly be the extension wire i am using? my tuner supplied me with an extension wire which is professionally made and heat wrapped and terminated properly into factory male/female plugs. this extension wire is also brand new. ive triple checked the wire routing and it is safe.
anybody got any ideas?
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
rosahan
Apr 3, 2015 04:24 PM
Jesperss
Jan 24, 2013 10:43 PM
Jesperss
Oct 30, 2012 07:41 PM
