Clicking Sound When Breaking...
Old Oct 7, 2006 | 08:48 PM
tomm9050's Avatar
tomm9050
I seem to have a clicking sound coming from the rear of the car under sight
braking pressure. If I were to guess it might be a brake line hitting something,
Steve of Steve's Auto clinic drove it, checked the calipers and found nothing,
as soon as I drove off it was back...any thoughts?
Old Oct 8, 2006 | 08:01 AM
joey1320's Avatar
joey1320
i have had a couple of cars with the same noise, have you had your brakes replaced?
if you did and you used aftermarket pads, it will probably be the pads shifting and smacking the calipers.
good luck!
Old Oct 8, 2006 | 09:50 AM
tomm9050's Avatar
tomm9050
no brand new 2006 S, 1700 miles.
brake pads / calipers checked out ok,
could it be something else?
Old Oct 8, 2006 | 09:53 AM
mitchman's Avatar
mitchman
Ours does the same thing (2000 miles). But it only seems to do it after you back up, apply the brakes and then move forward and apply the brakes.
Our Miata does the same thing and it's caused by the sway bar end links rotating and taping their housing. I haven't hadn't a chance to look at our Mini and see if its the same thing. But again, ours doesn't do it everytime we apply the brakes, so I'm not that concerned about it......yet.
Old Oct 8, 2006 | 09:55 AM
Spade's Avatar
Spade
I have this same problem/concern. Everything works fine but the click is creepy. It almost sounds like a piece of suspension or a loose bolt to something clicking in and then out of place... weird though for sure. I think it might be the stock calipers shifting. Any possible tightening there? Let me know how this fixes tom.
thanks
Spade
Old Oct 8, 2006 | 10:04 AM
tomm9050's Avatar
tomm9050
[quote=mitchman;1167312]Ours does the same thing (2000 miles). But it only seems to do it after you back up, apply the brakes and then move forward and apply the brakes.
That's it exactly, usually under light brake pressure, and not all the time.
like I said the mechanic checked the the brakes / drove it and found nothing wrong, but it persists
Old Oct 8, 2006 | 10:39 AM
ChiliCooperS's Avatar
ChiliCooperS
okay this is creepy my car started doing this about 2 weeks ago. It happens under brief acceleration then when u let off the gas but don't depress the clutch. I don't about braking haven't really been paying attention to it then... im sure it does though. Hmmm interesting problem...
Old Oct 8, 2006 | 10:44 AM
tomm9050's Avatar
tomm9050
I will try that / see if it that's what it is / what year is your MC?S?
Old Oct 8, 2006 | 02:10 PM
90STX's Avatar
90STX
Check to make sure that all of your lug bolts (or nuts if you have a stud conversion) are tight. 90lbs-ft.
Scott
90SM
Old Oct 8, 2006 | 02:22 PM
joey1320's Avatar
joey1320
i know you said somebody checked the brakes, but still i'll double check about the pads. i wasted about 1 1/2 on a customers car with the same complaint as yours. i checked the brakes, suspension, lines, lugs and everything else that could make such a noise and came up with nothing.
i then drove the car with another guy and after anger came over me i kicked the right rear tire and heard the noise. i kicked it again and sure enough the noise was there... i reached in and literraly moved the pads about 3mm up/down. that was it.
i tried to duplicate the problem for the customer and it didn't click.
after she walked back to the waiting area i tried to move the pads and they moved and clicked(of course when she's not there)...
so they may look ok, like i tought but i would still check/move them. also try putting some thick grease on the pads/brackets and see if it goes away.
good luck!
Old Oct 8, 2006 | 03:36 PM
tomm9050's Avatar
tomm9050
Scott
90SM
Thanks, Steve of Steve's auto clinic did check them / the fronts were loose from the factory!
Old Oct 8, 2006 | 03:39 PM
tomm9050's Avatar
tomm9050
Where do you put the grease?
Old Oct 8, 2006 | 05:12 PM
ChiliCooperS
yeah it's not my brake pads, because it happens when I don't apply the brakes at all. So i dunno...
I have a 2005 MINI Cooper S, with all the mods listed on the bottom, plus JCW Suspension and JCW Brake kit
Old Oct 8, 2006 | 05:19 PM
mitchman's Avatar
mitchman
Thanks Joey!!
Everyone Else: If that's really the problem, i wouldn't worry about it. But if you decide to apply some grease, be careful where you apply it. Make sure you use high-temp grease. NAPA sells little packets of "High-Temp Brake Grease" that works well.
You just don't want your brakes to heat up and then have the grease liquify and run into the brake pads.
Old Oct 8, 2006 | 08:18 PM
Gromit801's Avatar
Gromit801
Count me in also. Ah, the annoying little things that make us Mini owners!
Old Oct 9, 2006 | 05:52 AM
joey1320's Avatar
joey1320
the grease would go on the bracket that holds the pads, where the pads make contact with the bracket. that way there's not metal to metal contact.
Mini's does not apply grease to the bracket from the factory(i don't know why).
And when i found out that it was the pads, the car was parked and i just happen to get so frustrated that i kicked the tire and that's when i heard it.
good luck!
Old Oct 9, 2006 | 06:24 AM
MiniMacPR's Avatar
MiniMacPR
There are numerous 2005 MCS models that came with a clutch/flywheel problem from factory. Check with your SA, it's fixed & replaced under warranty. Do a search in the Performance Mods/Drivetrain forums and you'll find some info. I would imagine it's also around here in the Beneath the Bonnet forum but I haven't looked.
Good Luck
Old Oct 9, 2006 | 04:26 PM
borrowingamini's Avatar
borrowingamini
Me 2
My fiancee's 2006 Mini (350 miles) does the same. I'll have to double check but I recall it happening after reversing.
Old Oct 9, 2006 | 06:20 PM
Sissy's Avatar
Sissy
I've heard the same clicking sound while braking my 2006 MCS. It's intermittent. Just took delivery Saturday. I'll watch it this week and take it in if it's persistent.
Old Oct 11, 2006 | 01:36 PM
RudyT's Avatar
RudyT
I've got that same similar noise with my 06. Figured it was one of those features with the car.
Starting noticing it after my first hard braking. More noticable with backing up in reverse and then applying the brake. I made sure all of the lugs were torque to the correct specifications in the manual.
I plan on replacing the rear sway bar as it has been on the list of wanted mods this winter. Maybe this might solve the problem. The pads being a little loose sounds logical but not too worried about it.
Old Oct 11, 2006 | 02:03 PM
MINIyegor's Avatar
MINIyegor
I read somewhere that it's normal. There is some kind of brake system checking. It usually happens when starting driving or backing up. I have my second MINI now and it makes the clicking sound.
Aug 19, 2015 12:51 PM
damncajun
Aug 17, 2015 08:25 PM
Aug 12, 2015 01:24 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
