PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. is it possible to change the gearbox ...
  2. New Transmission : (
  3. Broken Lock
  4. Serpentine Belt Change
  5. Clutch engagement point
  6. What have I done??!!!
  7. Vibration noise from cold 1st gear starts from stop
  8. peculiar coolant/radiator issue
  9. Flywheel/clutch problem??
  10. Save money in Maryland
  11. sounds like exhaust has come apart from headers...
  12. Backfiring on cold start
  13. no brake lights ??
  14. Stock Driving Lights
  15. warranty cancelled
  16. Low RPM clatter, high RPM rattle. Something is loose?
  17. Brake fluid sensor wire
  18. Radiator pressure test ?
  19. ABS, Flat Tire Indicator, and DSC light on and won't go away
  20. Stumbling on acceleration (2004 MCS)
  21. reverse light drama
  22. Shredded belt, bad tensioner.
  23. Starting issues in 2004 cooper S - HELP!!
  24. Information on replacing the antenna housing.
  25. Help Need help, 04 Cooper S Howling noise
  26. Warranty…
  27. won't Start...
  28. SES Codes through On Board Computer
  29. Pot Hole Problem
  30. Some Weird Smell
  31. Floppy Accelerator Pedal
  32. Driver Side Window not going down when door opens/closes
  33. Headlight not working, Are these good?
  34. Mushrooming
  35. Passenger seatbelt warning light w/groceries
  36. Power steering pump is running constantly.
  37. JCW strut bar bent
  38. Replace Heated Mirror
  39. Where to buy an Oil Filter Housing
  40. Glove box rattle/removal
  41. Remote programming procedure question
  42. A/C Smoke
  43. Loose suspension / steering
  44. EML, Check Engine Light - looks like a Christmas tree in here!
  45. mysterious key problem
  46. EML on after GP Intercooler Install
  47. lights on???
  48. Our Possessed MINI Cooper
  49. New Transmission
  50. Power steering fan and split harness fix
  51. Antenna broken off
  52. SES and DSC lights on
  53. Quesiton about a few problems
  54. RECALLS?
  55. Rear brake caliper piston seal is torn
  56. passenger side motor mount
  57. Some Brake Service Questions
  58. Steering wheel/column "thump"
  59. Normal wear and tear ?
  60. Driver's Door Problem
  61. Alignment Issue
  62. Rear Spoiler Removal MCS
  63. Inside mirror day/night don't line up?
  64. Paint peeling from around front turn signals?
  65. werid front end noise/my cause
  66. Is it possible to fix a loose Glove Box latch?
  67. One brake light always on
  68. Sheared off a rear hanger muffler bolt
  69. HELP!! Can't Finish Oil Change & Can't Drive Car
  70. Outside Temperature Gauge Off
  71. installing when clutch down
  72. Problem with brake pedal
  73. Steering Noise when car is off
  74. Sunroof Not Working!
  75. Getting at the starter motor
  76. Any longer term solution for knocking steering? Please help, almost out of warranty
  77. Ripped Off !!
  78. Radio being fussy
  79. Fuel Gauge Problem
  80. P0108 code Overboost "I Found the problem"
  81. Clutch pedal...
  82. Speed Sensor Problem
  83. Front wheel bearing/hub replacement
  84. Brake Job
  85. Headlight will not shut off
  86. Clutch problem: vibration/whirring when pedal is depressed?
  87. engine fan keeps blowing fuse
  88. Starting issue
  89. Intermittant Air Conditioning?
  90. idling at 1100-1200
  91. Weird sound from steering column
  92. Is this normal?
  93. annoying engine noise inside the car
  94. High pitch noise coming from the engine bay
  95. 06 Cooper 6 months old - transmission needs to be replaced
  96. Grill Stolen; how do I put new one on?
  97. At 105,000 miles, 3 windshields...
  98. Transmission Problem
  99. Wasp nest on my intercooler
  100. Anyone ever run out of gas?
  101. Check Engine & Gas Mileage
  102. Auto A/C question
  103. Strange Noise
  104. EML, DSC, SES !
  105. Warranty Coverage
  106. Climate control illumination woes
  107. Connecting Rod Torque Specs
  108. TPMS light keeps coming on
  109. Sunroof Grease
  110. My fuel pump won't shut off!!
  111. Strong smell of toasting circuit board
  112. Engine clicking under acceleration?
  113. My cracked strut mount
  114. Error Code... can anyone decipher for me?
  115. Yellow warning light related to exhaust
  116. 2002 Cooper, roughness/vibration on low rpm accel.
  117. failed / leaking motor mount??
  118. Cleaner Reflector HID Beam?
  119. Where do I go?
  120. Service Engine Soon - p0326
  121. "Service Engine Soon" Light Comes On ; Might Have the Solution
  122. Thread for all KNOWN stock issues?
  123. 05 Auto Tranny Issues... Again!
  124. Verryyy weird help
  125. Seat back wont adjust
  126. 02 Sensors on ebay
  127. Driver-Side Lock/Unlock
  128. ALIGNMENT... MINI PULLS, NORMAL?
  129. CV joints not covered under waranty?
  130. Electrical issues?
  131. Driver-side Window -- No Worky
  132. Oil Change Problem
  133. first problem - wipers
  134. Door Lock/Unlock Issues
  135. when to change O2 sensor
  136. Seat and Steering Wheel
  137. Clutch Replacement (pic)
  138. Central Light Cluster?
  139. How do you change the bulbs in the side reflectors?
  140. New (to me) MINI! Rubbing issues...?
  141. car overheats!!
  142. MINI not designed to take higher speeds... (pic)
  143. 2002 Cooper manual transmission failure
  144. how to reset service warning
  145. New problems
  146. Axle Nut Torque Spec
  147. My driver's seat is alive!!!
  148. Are all MINI/BMW batteries crap?
  149. Electrical/charging issue
  150. Engine Stopping in slow traffic, But restarts fine
  151. Junky STOCK Bonnet stripes
  152. Rod Bearing's
  153. White Rims.
  154. MINI S questions
  155. Hoping this is a fluke and not CVT issues
  156. A/C RAN OUT
  157. Tire Pressure/ABS/ASC Alarm
  158. Clutch noise - pop and power lock nonsense
  159. MINI Throws a code -
  160. Decel Issue
  161. Automatic gearbox issues
  162. ABS LIGHT, RED BRAKE LIGHT AND DSC LIGHT ALL ON
  163. Engine shuts off!!!
  164. Adjusting the alignment of tailgate
  165. Engine Suspension Replacement
  166. Cruise Control Issue
  167. how to replace upper engine mount
  168. A/C - no cold air
  169. My first issue with the MINI when "Cruising" on highway...
  170. electrical drop = dead MINI
  171. Clacking/Knocking in Rear
  172. 2002 MINI Cooper S power steering pump
  173. need help
  174. I'm Done! GOOD BYE!
  175. CONSTANTLY getting SES P0456
  176. Reverse Light Wont Work
  177. Oil reset and SES light reset
  178. Squeaking noise in 03 MC, had the brakes checked and they are OK
  179. Front Seat Removal
  180. Brake and DSC Light
  181. 3 lights on
  182. Wierd problem.
  183. Repairing broken door lock yourself
  184. AC died then alive!
  185. Cruise control failure
  186. crooked exhaust?
  187. Rear Wiper Washer Problem
  188. Where can I buy Glove Compartment
  189. Power Steering Questions
  190. who rebuilds mini's rack+pinion steering
  191. Several problems with my 03 Mini
  192. Help! flat tire
  193. MAP Sensor Code P032?
  194. Clutch covered under warrenty?
  195. NYS Thruway +1 Mini 0
  196. P1125 and P0638 error codes
  197. '02 MCS EML light issue
  198. QUESTION FOR VETERAN MINI DRIVERS
  199. CVT intermittantly weak in reverse...?
  200. The how do you describe this sound/ is this normal thread
  201. Wanderlust or how many quirks till you fall out of love
  202. How do you know when your clutch is going out?
  203. Brake Lights Remaining On
  204. transmission/clutch problems/questions
  205. Dead '05 MINI Cooper S
  206. My car is possessed! No really, serious problems..
  207. Inserting key in ignition unlocks passenger door
  208. 60k service coundown reset
  209. Passenger window won't go down??
  210. difference in sound between broken pump/fan?
  211. won't start
  212. Popping Noise?
  213. How can I tell what # my car is?
  214. Trapped Wasp in Drivers window seal?
  215. motor mount replacment
  216. Drive axle seal
  217. Cylinder 1 Misfire Plus Data--Intrepret Please?
  218. Notchy shifting?
  219. 03mcs
  220. Clutch Problem !!
  221. HELP! Cruise Control Problem
  222. Weather Stripping
  223. Fess up to your MPG
  224. Cruise control failure
  225. Sold car, new owner has lots of problems?
  226. Window "klunking" fix
  227. Tensioner replacement without tool?
  228. C.V. Boot Replacement
  229. 04 MCS Crank Grind Specs?
  230. cooling fan noise & vibration
  231. First MINI problem non fuctioning headlight
  232. Diagnosing yet another PS pump inquiry
  233. Brake Booster Leak
  234. 1st problem(rack)1st post
  235. Odometer vs. Speedometer?
  236. Baton Rouge Brian Harris
  237. Seat back no longer adjusts
  238. Low clutch pedal engagement
  239. Cracking noise
  240. Low noise & vibration - PS fan?
  241. Battery indicator
  242. Insulation Burn on JCW Intercooler
  243. roof paint peeling
  244. 03 Model Year Problems
  245. how to test voltage regulator?
  246. Dead Fuel Pump
  247. air bag problem
  248. so my alternator is dying.
  249. Steering problem?
  250. Loud clicking from engine compartment until warmed up
