Flywheel/clutch problem??
On a cold start up I get a loud screeching noise when I let the clutch out. It happens only in first gear maybe once or twice and I don't hear it again until the next cold start up. Is this a sympton of the dreaded flywheel/clutch problem that I've seen on other threads? I have about 2500 more miles before the next inspection but I'm thinking maybe I should take it in now. It's a 250 mile round trip and a whole day at the dealer. Any advice??
I have a 2004 MCS that had this same problem. It was just as I let out the clutch and only a couple of times before it went away. I have 36000 miles and it had been doing it for quite a while. I took it to the local Mini Dealership (Flow Mini in NC) and they said it was a fluid leak that was getting onto the clutch plate and flywheel. They replaced both under warranty and fixed the leak and I have been squeek free ever since. If you search you can find the sound described as a screach, bark, squeek and other names but the fact that it only happens when the car has been sitting around a while and only happens the first few times you let out the clutch is the real telling factor.
Mike
Mike
Is there an offical recall on this problem or is it up to the Dealer to make or not make the repair. I can just hear the famous,"they all do that" line as they send you back out the door. I would like to have some kind of proof in order to plead my case. Any advice??
UncDeo
Nov 4, 2019 04:08 AM
Navigation & Audio Portable Navigation XL Wiring
mikeandtricie
Sep 4, 2015 01:42 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
