Oil reset and SES light reset
Old Aug 29, 2007 | 07:50 PM
kenros's Avatar
kenros
I installed a megan header and a borla cat-back on my '05 MC and 3 days later the "Service Engine Soon" light came on, I verified my o2 sensors and they look great and my car runs great, also I need to change my oil soon (4k) and I need to know how to do it by myself, I was looking for a rest tool and i found thi one on summit, I know that I can reset the SES with this tool but I want to know if I can reset the oil change miles with this tool too.
http://store.summitracing.com/partde...5&autoview=sku
I will appreciate any help
Old Aug 29, 2007 | 08:01 PM
Mini Works's Avatar
Mini Works
Not sure about that scanner,
a lot of us are using the Peake Research tool specific for Minis, check it out.
Victor
Old Aug 30, 2007 | 06:10 PM
Grassroots Garage's Avatar
Grassroots Garage
You don't need a special tool to reset the service indicator. You will find a how-to here - http://www.tech-esq.com/Site/Engine/...indicator.html
Old Aug 30, 2007 | 06:21 PM
kenros's Avatar
kenros
the reset is for 10,000 or 15,000? the last time that my oil was changed the millage was like 15,100 (new millage until next oil change), I read that the reset put a number depending on the mini use, I'm right?
Old Aug 30, 2007 | 06:52 PM
Grassroots Garage
When new, it counts down 10,000, after that, it count 15,000. The twist here is that is does actually count down miles, that is a calculation based on how much fuel is used. The ecu keeps track of injector "on" time. Some cars may need service sooner or later than others. I don't agree with 10-15,000 mile oil changes anyway, at least not if you want it to last a long time.
--Dan :{-
Old Aug 30, 2007 | 07:30 PM
kenros's Avatar
kenros
Tahnks for your help!!
Old Feb 9, 2008 | 06:36 PM
qweewq12's Avatar
qweewq12
For clarification, you can only reset the SES light with a OBDII reader?
Old Feb 9, 2008 | 09:02 PM
chpsk8's Avatar
chpsk8
Could probably do it by disconnecting the battery, stepping on the brakes to bleed the voltage and let it sit for 15 minutes. Then reconnect the battery. Light should be out.
Works for most other cars, should work for the Mini also.
Old Feb 10, 2008 | 05:20 AM
qweewq12's Avatar
qweewq12
Just tried the "disconnect neg battery term, press brake pedal for 10 secs and then wait 15 mins"... SES light was still there upon re-connect...
I do have a code reader (actron cp9125) coming this week, so I guess I will give that a go...
Old Feb 10, 2008 | 10:43 AM
CHILE_RED's Avatar
CHILE_RED
Thanks so much for the oil change reset info!!!!!!....I thought my service engine soon light was a problem or something but i reset my oil change thing and now its perfet no lights at all....Thanks again!!!
sevin
Feb 1, 2016 11:30 AM
Powershift
Aug 16, 2015 05:14 PM
JamJam43087
Aug 16, 2015 02:02 PM
quality_sound
Aug 7, 2015 09:36 AM
