PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. my temp gauge keeps going up and down
  2. Vacuum noise when off
  3. 2nd gear issues :(
  4. Mysterious Fluid
  5. Wiper Alignment Adjustment
  6. Brake problems I think....
  7. heres a problem that has me stumped
  8. melted pin in headlight harness, best fix?
  9. From Cam to Clutch
  10. Thermostat - OEM vs Wahler?
  11. '03 MCS JCW SES codes P0107 P0130 P0420 P1688 EML limp mode
  12. Fixing the Radiator Cooling Fan Problem on 02 MCS
  13. SES and code 1477
  14. SES light P0130 and P2096
  15. POR-15 on MINI rust
  16. Dimensions for belt tool
  17. Please recommend good brake pads
  18. Heated seats not coming on
  19. R53 Sunroof DOA, It just stopped working. Need Help
  20. Passanger Headlight Washer Not Working
  21. What the...
  22. Washer jets not working-help
  23. Replacement windshield markings
  24. Stupid DSC dash light question!
  25. Noises, any suggestions?
  26. New fix for broken tabs on MC Air Box
  27. Missing pinging rough idle
  28. MINI 5spd Midlands transmission, rebuild or replace?
  29. radiator fan - Carpartnation
  30. Front wheel bearings
  31. OEM SC Bypass Valve Forensic Analysis (pics)
  32. Pulley Removal Tool...Anyone near Temecula?
  33. MCSa problem/ big problem?
  34. Attention: Those with cars that shut off or stall for now reason...
  35. brake pad corrosion?
  36. Loose tie-rod ball joint - What to do?
  37. Fix for P0456?
  38. Recommended Clutch and Flywheel?
  39. Speaker not blown - just not screwed in
  40. Driver's window rattle
  41. P2404 code '05 MCC
  42. Sounds from inside the car :@
  43. New pads + rotors = thunking?
  44. Small - LEAK, dime size (blue-ish fluid)
  45. Help with radio shut off!
  46. Something is not right
  47. New Trans
  48. A few electrical questions
  49. WARNING:: OEM Plate frame causing RUST
  50. HELP!! Can't find "TMAP Sensor"
  51. Vibration - Acceleration & Coasting
  52. Auto Climate Control Help
  53. A/C pressure sensor switch question.. and other various things
  54. Worn control arms
  55. MINI goes boom...
  56. O2 Sensor Removal
  57. problems with my 04.....
  58. Fuel Pump
  59. Replacement with non-sealed battery?
  60. So I Tore A CV Boot
  61. A few areas of concern...
  62. Clutch Slave Bleeder Screw
  63. Drive Shaft or Motor Mount
  64. Noise when taking off
  65. Oil pan drain plug stripped
  66. Spark plug popped out - guidelines for driving it (or not)
  67. Front emblem coming loose
  68. P2300/P2303
  69. ASC light plus cam sensor engine light?
  70. Bent rear control arm?!
  71. Door Squeak
  72. 04 MCS with a leaking rack and pinion
  73. Trouble code?
  74. MINI Wings on Liftback
  75. Axle Carrier Bearing SOURCE
  76. Spring inside glove box latch gone bye-bye
  77. Coolant temp - bad fan??
  78. Having Problems Starting
  79. Random, resettable misfire?
  80. Dipstick shows nothing!
  81. Help needed, anyone got OEM airbox non-S/CVT you want to part with?
  82. ABS cutting in too early?
  83. My Heater is on high and it won't shut down!!!
  84. Removing front wiper arms
  85. Out-of-Warranty Motor Mount Replacement
  86. Radiator rust?
  87. Gages and lights going berzerk
  88. Right hand axle support bearing
  89. Replacing backup / reverse light
  90. $2000 for "warranty" work? I'm done with Coopers...
  91. MINI R50 with no OBC will not display temp, engine bogs down
  92. Changed oil - small amount of oil below car in morning
  93. Need to replace radiator..what options do I have?
  94. Gearbox options on 2003 Cooper (R50)
  95. Trunk Wont Stay Closed! What gives?!
  96. Power Door Lock Question
  97. How to replace right inner CV boot?
  98. Clicking Noise Under Dash, Clutch Relatied
  99. Brake Replacement 9 months after replacing?
  100. '02 MCS 6sp Shifter problem
  101. "Groaning" in low speed turns?
  102. Boot/trunk sensor
  103. How to find / determine bad wheel bearing?
  104. How far can I go after brake pad light comes on?
  105. Exhaust Flange Bolt
  106. Stock interior color name?
  107. Duration of brake rotors
  108. Buzing from the Dash
  109. replaced fuel filter - car will not start HELP
  110. Removing console around ebrake?
  111. Ray Latulipe
  112. Need black roof rack caps
  113. Location of Instrument Cluster Control Module
  114. Tranny rattling in neutral?
  115. That little plastic key
  116. salvage yard s/c or have mine remanufactured
  117. Possible bad pulley tensioner... video inside
  118. Replacement Supercharger
  119. Heater not blowing heat
  120. Battery condition affecting idle?
  121. Melted wire bundle - driver side headlight
  122. What is the maximum capacity for oem fuel injectors
  123. Replacement Windshield Rattles
  124. how do I remove the window?
  125. VERY hot hood near left light-WORRIED. HELP.
  126. Broken off a strut mount stud
  127. Alta intake breaks
  128. changed oil now engine light comes on
  129. Terrible Story
  130. Expensive trip home....
  131. heated seat question
  132. Weird electronics?
  133. Sunroof issues
  134. Broken headlight Clip
  135. The infamous Airbag Light
  136. Not as snappy as it once was...
  137. ELECTRICAL PROBLEM PLZZZ HELP ME!!!!!
  138. Radio works intermittently
  139. Knocking!!! Now what?
  140. Shifter getting harder to shift
  141. Which 3rd Party Extended Warranty will cover CVT auto trans?
  142. AC no work =( help!!!
  143. HELP! Glove box door on my 05 S will not OPEN
  144. MINI Cooper massive amount of trouble codes
  145. I need advice, MINI won't start after replacing several things
  146. Won't shift into 2nd, 4th or 6th
  147. couple of Q's (coolant & PS fluid)
  148. code p0130 in 04 MCS
  149. Heater Core Replacement
  150. My temp shows in C, not F! Why? How?
  151. Blowin HKs
  152. Cross reference parts list
  153. Can an RSB Install Impact Rear Wheel Alignment?
  154. 02 oxygen sensor questions
  155. oil change / Inspection I & II confusion
  156. HELP! Got a Cooper block?
  157. Need help for my 2006 base Cooper!!!
  158. Mushrooming / Strut Mount Warped?
  159. Oil Leak
  160. O2 Oxygen Sensor Help please
  161. Steering is creeking
  162. Corrosion on #2 ignition coil lead
  163. Green Fluid Leak
  164. ECU wire-short, MINI help?
  165. Sunroof problems
  166. Muffler hanging bracket rusted and broke!
  167. Clicking sound from steering
  168. Electrical gremlin?
  169. NEED HELP WITH THIS ISSUE PLEASE
  170. My '06 JCW S continues to get 14.5 MPG after a trip to the dealer. Help!
  171. Increased engine noise after service
  172. Problems using factory warranty on used car?
  173. another door lock problem HELP!
  174. Abs randomly engaging
  175. DSC/Tire every time?
  176. AC compressor clutch sticks...
  177. Door Closing issue.
  178. '05 S w/DSC Brake Master Cylinder not available?
  179. pop sound/backfire in 2nd Gear
  180. Rust-to-be areas?
  181. Intermitant Static from Speakers/Radio on but no sound
  182. how bad the power steering has to be to get an warranty
  183. I think my power steering pump finally died.
  184. Xenon question...easy
  185. Weird stuff going on during start-up
  186. Anybody try to repair fan housing resistor?
  187. Problem with aircon and minor problem when starting up the car
  188. 04 Cooper S ballast question
  189. Clicking at idle
  190. Electronic Window Malfunction?
  191. engine wont acelerate
  192. Loose Gas Cap P0456
  193. CD player controls not responding...
  194. Wheel problem
  195. Help Please - Reset LEW Procedure?
  196. Alignment results
  197. Water in battery compartment
  198. Boot Bungle Bingo?
  199. Driver's seat reposition problem
  200. Need help diagnosing a possible power steering issue
  201. Strange warning light
  202. ABS and Battery yellow light on when stopping
  203. dealer says supercharger bearing? I say idler pulley
  204. Dead Mini
  205. Urgent: Low RPM oil pressure again
  206. Exhaust Diagnosis, Please
  207. reclining seat syndrom, help!
  208. Put car in reverse does not move (sporadic)
  209. Top frame rattle
  210. Brake light issue??
  211. MINI Stopped while driving on highway!
  212. 2006 S clutch rattle
  213. Which 02 sensor to replace
  214. 2006 cooper s engine rattle
  215. Oil Pressure Sender?
  216. Bad Noise - Upper Engine
  217. Front Wiper Motor going out. (I think)
  218. Replacing the steering angle sensor???
  219. My dead MINI
  220. Odometer flickering
  221. Front end squeak
  222. mini next will it cover this
  223. Power Steering
  224. Replacing Clutch Hydrolic Lines...Advice?
  225. All Left Side Markers Stuck On
  226. "Misfire Cylinder 3" code...
  227. Running Lean
  228. Tie rod end removal?
  229. Service Warranty...what a joke!
  230. clutch troubles
  231. Boot Sensor bad?
  232. Squishy brakes, failed tech inspection
  233. getting bummed
  234. Measuring Water temp?
  235. no power to wheels!!!!
  236. Diagnostic Scan Tool
  237. 08343 - undocumented code -- HELP
  238. "clunk" and "tunk" from the engine/suspension?
  239. Fuse 37 keeps popping.
  240. Xenon Headlight woes
  241. 2007 Cooper Standard shift "Will NOT Start" Problem solved - Bulliten
  242. I stopped all dash rattles & squeaks!!!
  243. Low tire pressure light
  244. Speedo reads 5-15mph STOPPED!
  245. BMW Technical Information System
  246. Keep or sell?
  247. CVT?
  248. Wheel alignment/wheel balancing issue?
  249. power steering pump location
  250. MCS Fault Code P0704?
