View Full Version : Stock Problems/Issues
- NO!!! OMG I see RUST on my 2005 !!!
- Door lock issue
- 2002 needs a tranny
- Unlock all doors at once?
- How to fix window seal on the outside and wheel arch trim?
- Auto trans info
- Hard to start
- I've had it up to here with my front suspension
- Mysterious Battery Problem....
- Does anyone know the name of this part?
- Inconsistant power?
- Wipers quit working
- CVT small problem
- Low Water Temp/High Intake Air Temps
- mcs 2002 no power CODE P0341
- R53 problems
- Noises when shifting
- SES light on, losing power @ idle
- DSC, ABS, Tire lights on
- Is replacing an axle half shaft and wishbone a DIY project?
- oil cap leaking
- Water in Engine oil
- Urgent!!:: Car Won't Start...Lights Don't Even Come On
- Key won't charge
- electrical gremlins redux
- Door groans, my ears bleed
- Car won't lock!
- rally light help!?
- Car Wouldn't Ideal Right
- Oil leak, need suggestions
- Power Steering not shutting off
- steering wheel ain't centered...
- Silver, metalic fluid leak.
- How to tighten the strut top nut?
- CVT Repair
- 04 Cooper: annoying on/off throttle jerk
- Video: Clutch noise..... HELP!
- MINI is cutting off when i start it up. i think its the fuel pump
- So We Were Getting Estimates Today
- Urgent!!:: Car won't start, even with a new battery!!!
- glove box chrome
- Bearing noise/whine
- Oil Temp fluctuation.
- POWER STEERING DIED 2003 MINI
- Chrome bit on the parking brake
- Cold start rattle question
- No oil Mini
- '05 driver's side door stopped locking/unlocking electronically
- Headlight not working!
- Lost Oil Fill Cap
- R52 Blowing PDC 5amp Fuse
- Broken glove box lock for '05 MINI Cooper S, any suggestions?!
- rattling sound below control buttons
- 2002 Mini Cooper S Help Needed
- Driver's door problem
- Gear Shift Sticking, Causes? Suggestions?
- Grinding noise.
- Problem with sunroof
- Coolant temp gauge close to 200F
- 2005 Mini Cooper Convertible - Overheating for 2 years
- 05 mini cooper s service engine soon light!
- Please help re: tachometer computer display not working
- Results after boost gauge install
- Air Conditioning Problem
- Rough Idel and Cylinder 3 Misfire
- Electrical Demons in the hatch/lighting
- Lost Clutch over night
- Any way to "guess" torque without a torque wrench?
- Program '04 key fob? Must go to dealer!
- squel/clunking noise from engine area?
- 04 MCS and battery/door issue
- Something Doesn't Smell Right
- Mesh screen in oil filter housing?
- Mini Cooper S - wheel problems...
- Gauge auto test wierdness at startup.
- Clutch pedal squeaks/groans when warm
- Clutch / Gearbox Situation HELP PLEASE!!!!
- head gasket replacement
- Service Engine Soon Light Issues - Please Help!
- Check Engine Light and Just bought my JCW! Hearing Fireworks!
- Parking sensor fuse keeps blowing
- Car won't start...Not the battery
- Mini won't start...Not the Battery
- Ticking noise coming from rear right.
- rattling clutch.
- Passenger Airbag Warning Light
- fog light bulb
- Mini Dead after stall and 1 restart. now no dash lights, good battery
- 40,000 mcs
- HELP!! Where is Air Temp. Sensor???
- P0420 BANK 1 O2 sensor
- rattle?
- Timing valvetrain and bottom end?
- Body Color washing off under hood
- Removing teflon coating on head and block mating surfaces?
- R53 has no reverse light.. help
- R53 Upgraded Thermostat Housing?
- Power Steering Noise
- Power Steering Fluid Question
- 2002 mini manual tranny fluid
- Fan and overheating
- HELP I cant open my passenger door from inside or out
- Strut tower - Hammer?
- Crank pulley wobble and engine knock
- '06 Sunroof sometimes so slow!
- Oil pressure light flickering....
- Heater Core (?) Advice/Assistance
- Help!! Can't go over 4k RPM or else I'm limp!! Help!!
- Soon to be no more Mini Cooper S...
- Strut Boot
- Oil Leak!
- Clicking sound from passenger seat in a 2006 Cooper S
- Keychain Remote
- Ever Change Differential Fluid?
- Sticky Clutch issue
- rust
- Head removal: how do I take out the two plugs to access the chain tensioner?
- power steering fluid
- EWS failure mode?
- Leak-prone areas?
- Crank sensor o ring
- OBD II port no power or signal
- Driving lights.......
- Oil Leak
- Dealer says Limp Mode is because of faulty damper!
- taking on water in the rear
- Too much seafoam??
- Odd overheat.....
- nav staying on, draining battery
- Head removal
- tachometer/speedo/dash lights acting up
- Passenger headlight went out
- I can't figure out how to set the clock/time on the odometer!
- Couple Questions
- r53 with 6 speed paddle shift tranny
- Round and Round I go...
- Supercharger Parasitic Drag and whine
- My Mini is sick! Need some help please!
- Flashing Engine emission light
- Getting ready for some 100k maintenance!
- electrical system brain fart
- Clutch Problems
- Codes EML and idle issues
- Couple of questions about 04 S
- Power Steering lines
- clock keeps going bye-bye
- 2003 MCS Misfire & Spark plug change
- Faulty temp sensor?
- Tweeter/Door Handle Rattle
- Axle replacement, FEQ not acceptable
- HELP NEEDED WITH CV SHAFT
- Headlight Alignment
- First service
- White Smoke from exhaust!
- very weird coolant loss
- Top won't retract past sunroof stage! Help!
- My roof won't retract past sunroof stage!
- Pulled plug #2, soaked in oil and metal bits...
- Engine stop at 5000RPM
- Do I need a new Steering Column? Or...
- Running on three cylinders?!
- Minor run in with pothole, now clunk in large curb
- Powersteering once again.
- Rain Gutter Replacement
- Help with lower control arm bushing replacement
- to many codes...help please
- Potential
- Does this mean it's time for a new radiator?
- a/c and radiator fan?
- Steering Angle Sensor Failure?
- a/c and engine fan.
- Exhaust Heat Shield Bolt Size
- 2004 Cooper HID Question
- Mini wont go into gear
- Where Does the OBD Plug-in?
- oil change
- Red Brake Warning - Engine Red Line
- Start problems
- How easy should the supercharger spin?
- Replaced all 4 headlight bulbs, now left side hi and lo are out--HELP!
- Rear tire cupping...any thoughts
- quick diognosis please (yellow liquid)
- Parking lights
- Front Motor and Transmission Mount
- Rattles and noises from door mounted armrest
- 2002 R53 Drivers door will not open
- What is a cycle for OBD II for Emisson Testing
- Flat Tire warning light?
- Door Locks....funny...kind of
- CRAZY LIGHTS!!!! HELP PLEASE
- Cracked intake manifold
- Squeaky Seat back
- Need a Used 2003 Cooper S Exhaust Manifold & Cat
- New muffler?
- Problems with my MINI
- Strange noise in 2nd and 4th gear
- Climate control dial removal
- Rear Hatch Leak
- to-do list prior to warranty expiration?
- Steering Wheel Wobble & Tie-Rod Replacement Questions, Possibly Wheel Bearing
- Oil Filter Housing
- Rotor T50!
- Need technical help with Fault Code P1125
- dome light problems
- Seat belt will not fully retract
- Over heating and can't find a Leak.
- 2003 S - Replacing the fan blower
- ECU Reset Problem
- need help with my 2002 mini
- Vibrates at 3k+
- SEAFOAM PROCESS / THEN 1688 DIAG AND LIMP MODE
- synchros
- Passenger Window
- Replacement Windshield and Rain Sensor
- Shifter Cable Tool
- New Replacement Windshield and Rain Sensor
- Issue after changing clutch
- R50 Front Bumper chrome trim replacement Q
- Where can I get this part? please help!
- Out of Warranty Issues
- power steering fan runs when?
- Door Key lock/unlock won't work
- rattling noise from inside, ceiling area on driver's side
- I Hope you Know
- Front End Noise
- Any super smart people here?! (help needed)
- Cracked Valve cover
- Rack and Pinion Question
- Speaker Blown, Warranty?
- No signal to ECM from MAP sensor - please help
- Door Problems and one buried 04 MCS
- How do you change the clutch
- Is this whirring noise normal? *VID*
- How does my harmonic balancer look? *PICS*
- Shifter bushings
- Replace your rear wiper blade without going to the dealer!
- HELP:!! My R53 battery is locked out! Cant open latch!
- Boot won't open - how do I fix it myself?
- driver door wont open
- over Warranty Time but Under Miles
- Auto Shift problems - 05 MCa
- Axle bearing leak & bad welding joint (muffler)
- Brake lights dont light up.
- Any Luck with Lemon Law? 05 MCC
- My car is a mess need some help
- 03 cooper S water pump gear
- Tachometer red line lights don't work?
- ('06 MCS w/49,250 miles) Losing Coolant + White Cream in Oil = Fanfreakintastic
- Missfire cylinder 3 at track
