Passenger headlight went out
Old Mar 13, 2010 | 11:55 AM
iamhypnotic's Avatar
iamhypnotic
Hi i got pulled over the other night for my passenger headlight being out and when i got home i switched off my headlights then back on and both powered up. The passenger one flickers slightly when both are on now. After driving for a while the same light turns off. I opened my hood to see if anything is loose but cant really tell and i dont want to start taking anything apart without knowing what im doing. Any help??
Old Mar 13, 2010 | 12:16 PM
Rich.Wolfson's Avatar
Rich.Wolfson
The same thing happened to me. I am assuming your have Xenons? Artoo is an '03. I bought a used igniter on eBay as I think that is the part that goes. That way when it happens again or more often, I'll be ready.
Rich
Old Mar 13, 2010 | 12:22 PM
iamhypnotic
yea i have xenons and my mini is an 03 how do i check this igniter to see if its bad?
Old Mar 14, 2010 | 10:25 AM
DaveVT02S's Avatar
DaveVT02S
Pull the bulbs (don't touch the glass) and swap them side for side, then try them - if the 'flicker' moves w/ the bulb, it's the bulb - if the same side (pass, in your case) stays 'bad', it's the ignitor/ballast/silver box thingie...
It could also be the plug is loose, but you'll discover that when you go to disconnect it...
Good Luck!
Old Mar 14, 2010 | 06:33 PM
Rich.Wolfson
I don't think it is testable. But the reports from those where the problem gets worse than infrequent and are cured but a few turn on and offs, are that the igniter fixes it. I think if the bulb itself was bad it would be out more often than not. That is why I bought an igniter and put in in my parts drawer just in case. There is also a thermostat and housing as well as a belt in that drawer.
Rich
Burkee52
Electrical
Sep 18, 2015 11:12 AM
Sterling Thompson
Sep 9, 2015 08:16 PM
bbak11010
Sep 7, 2015 08:08 PM
tylewis
Sep 6, 2015 07:36 PM
Ntety
Sep 2, 2015 08:39 PM
