PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. Official name for wheel well liner?
  2. Low tire light came on an on an on
  3. DEALER JUST REPLACED DUAL MASS FLYWHEEL
  4. I'm assuming this is normal...
  5. Oil Leak
  6. Door Locks won't lock with toggle or key!!
  7. ABS Light/ Tire light
  8. Broken door handle
  9. Warranty inquiry
  10. Car Shuts Off While Idling
  11. Need help from someone who has done KD Backtap or something similar...
  12. 04 cooper hesitates when stomping accelerator.
  13. Felt around the sunroof on exterior
  14. Stupid Instrument Lights!
  15. Don't wait for the Dealership to change the Intake Filter!
  16. Back Up Beep
  17. my horn is dead. where do i begin?
  18. P0105 Fault ??
  19. Check Engine Light and Tire Pressure monitoring
  20. Mini research
  21. blinking A/C light
  22. "Service Engine Soon" Light On -- Reset?
  23. Squeeky rattle noise from front of car
  24. Pulsating power
  25. Wishing for a "Sticky" on CVT's
  26. Fuel pump fuse keeps blowing!
  27. Dashlights Flicker on and off
  28. Need Clutch Help!!!
  29. Manually Lowering Window?
  30. Ticking every 3 seconds from Dashboard area
  31. Cant take off the OEM Exhaust Tips!!
  32. My Car Just Zapped. Requiring help!!! Someone.
  33. Motor mount part #
  34. Throw out bearing ?
  35. Belt tensioner is leaking
  36. Radio (cd) skipping
  37. lower end block for S and non S
  38. 02 MC Electrical Problem
  39. 2004 Base Cooper Spring loaded filter housing
  40. OBDII Software/Cable
  41. ABS Module
  42. MCS Puking foam
  43. Electrical issue
  44. windows freaking
  45. overheating 2002
  46. 3 warning lights???
  47. Right Headlight Brighter Than Left
  48. Coolant Problem- Need Advice
  49. Power Steering Pump Failing?
  50. MPG Questions
  51. parts online
  52. Noise/thumping while De-accelerating
  53. So I'm dragging a cable...
  54. Funky Dash Noise when Changing Temp on Temp Gauge
  55. Instrument Light Problems.
  56. My clutch pressure plate might be broken
  57. Moonroof Issues
  58. Dreadful Smell
  59. Extended Warranty or NOT!
  60. Use of non-MINI coolant
  61. My coolant reservoir appears empty 2005 S
  62. My 2005 S won't shut down normally when I turn off the ignition
  63. Heated Seat wont turn on
  64. No Rust on 2002.......
  65. Sudden surge!?!?!
  66. What's this leak?
  67. Dose not idle. HELP.
  68. Knocking sound on acceleration and braking - NOT motor mount
  69. Oil Pressure? or Sending Unit?
  70. Plug Wire Mix Up
  71. CVT reinitialized? Shuddering when stopping
  72. stock problems/yo yo
  73. Power Steering Went
  74. engine stutters in 1st to 2nd
  75. Crunchy steering
  76. I hate steam
  77. BMW Based extended warranty?
  78. Newbie : What should I lQQk 4
  79. MINI won't start electronics not working
  80. Noise from headers?
  81. MotorMount Issue
  82. A/C loses power, windshield wipers come on by themselves!
  83. Odd noise from the rear
  84. Radiator Troubles
  85. MINI Won't Start
  86. hot air out of dash top side defroster vents?
  87. vibration when accelerating
  88. Stutter on acceleration...
  89. Key for Mini bike rack
  90. Leaking Strut?
  91. Exhaust Flex Joint problem
  92. More spark plugs woes... stripped?
  93. OBC Display with Chrono Pack
  94. any sugestions tires
  95. Spark Plug Popped Out!!!
  96. Windshield Whistling
  97. Clutch Problem, help!
  98. Rubbing noise
  99. Help, airbag light
  100. Finally I Get to Drive My MINI - Thanks Pestige MINI!
  101. '02-'03 issue with spring & check valve in oil pump area?
  102. Clutch Replacement?
  103. Reset Service Oil reminder
  104. front and rear badges
  105. Too lean code
  106. Found a hole burned in the bottom edge of drivers seat back!
  107. Warranty/Maintenance Dealio?
  108. Should we start a SubForum for High Mileage?
  109. whir-whir-whir from 40kph up
  110. Factory Driving Light RUST!
  111. Common issues with an 2003 Cooper
  112. Movement of slave cylinder!
  113. Tapping/Knocking When in Neutral
  114. ABS scan tool
  115. Cig Lighter not working.
  116. Boot buzz after pressing release button...
  117. Burble or Engine Pop?
  118. Bad battery or bad starter motor ?
  119. mini urinating
  120. Great Vacation and then...roadside assistance
  121. Magnetic Oil Drain Plug for MC 2004
  122. Does anyone have an account with ALLDATAdiy.com ?
  123. Replace serpentine belt
  124. Brake Pads...and Rotors, too?
  125. What to do when you're an idiot (Trim Damage)
  126. Oil Change Cost @ Dealer
  127. Speedo buzz then reset
  128. Over Boost Codes. :(
  129. Squeaky/Crackly Arm Rest?
  130. Horrible Day(warranty sucks)
  131. Stumble in 2nd
  132. Wiper knocking over 50mph
  133. Poor Gas mileage 05 MCSa
  134. Cooling Fan Low Speed Specification
  135. Random Noise
  136. Click?
  137. Wiper/Spray Coordination
  138. Passenger Seat Back Will Not Lock Into Upright Position
  139. another weird noise thread
  140. '03 Wiper and Washer stopped working. Any Ideas?
  141. Doors Lock and Lock and Lock
  142. Radiator fan resistor...
  143. Leak Pump Location
  144. Windshield interior
  145. Replacing brake light bulb
  146. Airbag, cruise, radio functions dead
  147. Airbag light comes on when a passenger is in the car
  148. Engine Ticking - '04 MC - Is this Normal?
  149. blocked windshield spray nozzle
  150. MCS Motor Mount
  151. Would someone tell me the sparkplug gap for an '02?
  152. EML, Service Engine Soon, Limp Mode
  153. Stress-Cracked Windshield
  154. No Front Wipers-FIXED!
  155. Hard Shifting with an 05 Cooper S
  156. My MCS Rattles like hell!!!!
  157. Remote Key Problem
  158. Speedo off?
  159. Problem discovered during first oil change
  160. Front Speakers Squealing
  161. Tire Questions???
  162. Chug Chug Dies
  163. Supercharger
  164. a/c compressor not shutting off
  165. Body Control Module
  166. Undocumented dash warning light - what is it?
  167. My bonnet wont open ??
  168. Sluggish Acceleration and Noise from Engine.
  169. Cracked Windshield Replacement
  170. Passenger door lock
  171. Squeaky Steering Wheel/Column
  172. GREASY FILM ON FRONT WHEELS
  173. Weird Sounds....
  174. flapping noise on acceleration???
  175. P1237 Again
  176. Power loss at high rpm
  177. question from a newbie
  178. Bently Scans Requested or Header and Motor Mount replacement
  179. Clutch not engaging after tranny install
  180. Dead window, no warning
  181. Leaking Fluid
  182. lost my wheel lock! now what???
  183. Minimum Rotor Thickness?
  184. Water problem...
  185. Simple Window Position Adjustment
  186. Tire Pressure Monitor
  187. Air Bag Light
  188. Help!!! Seat Belt stuck around wheelchain in cargo area
  189. Help!!! Seat Belt stuck around wheelchain in cargo area
  190. Bad Sulfur Smell... Odd Dealer Experience...
  191. HELP! HELP! HELP! Bentley Manual Scans needed!
  192. Stereo turns on, no sound from any speakers...
  193. Rubbing sound from tires at slow speeds.
  194. window regulator/motor problems...HELP!
  195. Freezing/thawing doors
  196. Bentley Manual Help Needed for Wipers
  197. P1688 On a Non S?
  198. Indirect TPMS not resetting
  199. slow coolant loss
  200. Cold Shifting (Very Cold)
  201. Valve Cover Seal breaking at 40K miles?
  202. Overheating*NEED HELP*
  203. Inside passenger side vanity mirror
  204. steering wheel vibration at high speed
  205. mini service
  206. Dull, brand new, oem, Xenon
  207. Weird Overheating
  208. Newb Service Mileage Question
  209. Brake question
  210. Reverse
  211. Door locks not unlocking with remote any more
  212. Any more detailed steps to replacing alternator?
  213. Please help p0301 and p0313
  214. Window adjusting, how to:??
  215. Windshield Wiper Problem
  216. Seat Height Lever/Arm help.
  217. '04 Clutch rattle
  218. Oil Change Interval
  219. Help to adjust windows on an 05
  220. awful groaning from rear of my mini
  221. Handling problems
  222. loud interior noise help
  223. Front end parts diagram?
  224. electrical issues with interior accessories
  225. Airbag light on & transmission leak
  226. Help with a decision about troubled new mini
  227. Overheating leading to master cylinder failure?
  228. Surely I'm not the only one who hates our oil filters
  229. Weird feeling clutch pedal
  230. Could these issues be due to a bad wiring harness? Can I trade in with these issues?
  231. Where to start...
  232. Vacuum Hose Identification!! HELP!!!
  233. Need help with overheating/thermostat
  234. Power steering issues - please help!
  235. tire pressure monitor
  236. oil filter location
  237. Buying a 2003 MINI Cooper S - need feedback
  238. Tire pressure light is on.
  239. Anyone know where to add freon?
  240. heat on; car overheats, heat off all ok
  241. Serp belt?
  242. oil around valve cover
  243. CVT experiences. good or bad?
  244. Chewie in My Clutch: Diagnosis und Fix
  245. Fuel system cleaning?
  246. One problem to the next
  247. Mechanic? - Palm Springs/Palm Desert
  248. GPS software..?
  249. Pressure Under Valve Cover!?!
  250. Power Steering Fan?
