Manually Lowering Window?
Old Apr 2, 2008 | 07:07 PM
AdmiralKit's Avatar
AdmiralKit
The motor for my driver-side window went out a few months ago, but since the weather is starting to get nice I'm finally getting around to fixing it. Unfortunately, the window is stuck in the up position, and the Haynes manual says that I have to remove the window in order to replace the window motor. I need to lower the window to get to the bolts to remove the window, but since the motor doesn't work that seems to be a problem. Any suggestions?
Old Apr 2, 2008 | 07:16 PM
ANT818's Avatar
ANT818
Your service advisor should be able to give you some advice. Isn't the car under warranty?
Old Apr 2, 2008 | 07:29 PM
AdmiralKit's Avatar
AdmiralKit
...And that's what I get for posting with 3 hours of sleep in the past 60 hours. It's a 1st Gen Mini Cooper S (2002). If any mods swing through here, could I get this moved to the 1st Gen Stock Issues/Problems?
Old Apr 3, 2008 | 10:39 AM
Krut's Avatar
Krut
'Tis moved. :-) I haven't heard of any 2nd Gen window motors failing yet. :-)
Old Apr 3, 2008 | 11:37 AM
Eric_Rowland's Avatar
Eric_Rowland
Originally Posted by AdmiralKit
...Any suggestions?
Start with banging on the door between the handle and the speaker while holding the window switch down. That's been known to temporarily 'fix' the motor - apparently the brushes stick.
cawwwtun
May 3, 2016 08:03 AM
theblackfalcon
Oct 11, 2015 09:49 AM
loop4re7
Oct 5, 2015 09:53 PM
minipopkart
Aug 13, 2015 05:22 AM
