blocked windshield spray nozzle
Old Feb 29, 2008 | 02:47 PM
kevin barrett's Avatar
kevin barrett
Has anyone had a blocked nozzle, my pass side nozzle is not working and as a result the other nozzle {there are a pair} shoots really far over missing the windshield completely! I know I have to remove the sound deadening material to get to the tubes, and I have tried to clear the nozzle with a fine wire but it still dosen't work . Any ideas?
Old Feb 29, 2008 | 03:41 PM
Striped Toad's Avatar
Striped Toad
Thats funny, i thought i was the only one having problems with that. My drivers side works perfect, but the pass. side, one works good while the other shoots over my car (im buying fluid to clean my windshield, not others, so would like to fix it)
miniconcarne's Avatar
miniconcarne
I've been lucky and had success with poking the holes, , maybe try a squirt of compressed air. That is if can access an air compressor with rubber tipped air nozzle. Just be carefull with the pressure.
Old Feb 29, 2008 | 06:57 PM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
unclog
I'll bet that the nozzles are plugged with wax. Try my universal wax solvent: Equal parts water and isopropyl alcohol with a few drops of dish washing detergent. Apply this to the nozzles with an eye dropper. I think this will clear the clog. Only one down side, you will have to CAREFULLY rewax the area around the nozzles.
Old Feb 29, 2008 | 07:03 PM
miniconcarne
mininut, I love the Half Moon Bay area, Pacifica, 101 ect.. ok back to clogs.
Old Mar 1, 2008 | 06:49 PM
healey67's Avatar
healey67
just go get a small safety pin or similar and clean them out. you can put the pin in the whole and move the sprayer sround to spray properly on your windshield.
Old Mar 2, 2008 | 05:07 AM
bonmot's Avatar
bonmot
I had an aiming problem (two of the four streams shooting over the car's roofline). While my MINI was in for other service, I had the dealer fix it. I believe there are very specific marks on the windscreen which the streams are supposed to hit. If you're under warranty, I'd ask the dealer to fix this sort of problem.
Old Mar 2, 2008 | 07:47 AM
whiteyanderson's Avatar
whiteyanderson
try a safety pin, dip the tip in vinegar and poke around in the jet.
Old Mar 2, 2008 | 08:44 AM
Dr Obnxs's Avatar
Dr Obnxs
If there's crap in there that won't dissolve...
that will just buy time. Take the nozzle off, blow it out with compressed air, and put it back on. That's the only way to do it for sure.
Matt
Old Mar 2, 2008 | 09:10 AM
101101's Avatar
101101
All this time I thought there was only one jet on the pass side nozzle; the other one's been blocked since I got the car. Looks like I'll need to buy a can of air.
Old Mar 2, 2008 | 01:13 PM
Striped Toad
I figured it out- after actually looking at the spray nozzles, it seems they are positionable, the one that i was having trouble with was just aimed high. easily fixed- just took a pen and moved it down.
IQRaceworks
53
Jun 28, 2024 07:29 AM
M7Speed
Jul 10, 2018 09:26 AM
Doc Pain
Oct 28, 2015 07:09 PM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
EVMini
Sep 28, 2015 10:20 AM
