Over Boost Codes. :(
Old Mar 5, 2008 | 07:10 PM
simplekid15's Avatar
simplekid15
Yesterday I just pulled 2 codes they were -
p1242 - Secondary upstream manifold air pressure sensor too high in deceleration
p1238 - Secondary upstream manifold air pressure sensor high input
I know these are over boost codes but how the heck am I throwing codes with a 17% pulley and a JCW head!?
Day Conditions when i got the code - 40f cold
Could someone tell me what's going on?
What should I do?
Get a higher flowing head?
Old Mar 6, 2008 | 09:30 PM
guidmini's Avatar
guidmini
Make3 sure the boost control valve is functioning properly.
Make sure when the car is off. The boost vale somes to rest @ its stop.
Old Mar 6, 2008 | 10:01 PM
simplekid15
What do you mean boost vale rest? like goes to 0? I don't understand.
Old Mar 6, 2008 | 11:19 PM
k-huevo's Avatar
k-huevo
By pass valve (BPV), looking at the intercooler, place your hand to the right of the intercooler output duct and follow it down toward the intake manifold, the BPV has a small plastic arm attached to a lever, actuate (press) the little arm with your finger and feel for ease of movement, it should spring back contacting the end stop. If it doesn’t operate freely or doesn’t return, it will need replacement; it is a warrantee item.
My BPV failures manifested themselves at lower rpm but it's worth a look.
Old Mar 7, 2008 | 07:55 AM
simplekid15
Just checked that and it was all springy. Looked fine. Any other sugestions?
Old Mar 7, 2008 | 10:27 AM
NOTDULL's Avatar
NOTDULL
My Similiar Codes
After I chased around and changed both the TMAP and MAP sensors, thinking it was the BPV all the time, it was actually due to a vacuum leak. Find someone to do a "smoke test" on your intake.
Good Luck
Old Mar 7, 2008 | 11:29 AM
simplekid15
A "smoke test" ? Could The MINI Center do this? Could you elabrate more on what this is?
Fordgt4
Oct 10, 2015 10:42 AM
Oct 1, 2015 12:13 PM
patsum
Sep 30, 2015 02:10 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
