View Full Version : Stock Problems/Issues
- Are we Flat Tappet engines on the S
- Headlamp problem
- Strange Electronic Problems
- HELP! Need new MCS engine. Can anyone help?
- 04' MCS w/nav. and no temp. guage?
- Strange Engine Issues
- Boot Leaking
- Wheel Noise Problem
- where can we access TSBs now?
- Strange new vibration
- door trouble on my '03 MC
- Annoying squeak
- BC1 part number?
- Anybody with 15% pulley have tensioner replaced
- Engine Issue 2003 MINI
- windows leak...
- Knocking noise coming from... the dash?!
- MINI problems - HELP please
- Even MINI techs have trouble with this one
- Chrome mirror caps question...
- Bad high speed wobble
- Separate rear windshield fluid pump?
- My engine stumbled a bit while parked... anyone know if this is something serious?
- Parking Light Lense
- OEM Clutch Question
- What to add to 2002 mini s?
- Help: Replacement Windshield – Wind Noise
- Need to remove some parts
- wipers are crap!!
- Power steering fluid leaking from reservoir
- Cheap plastic parts!
- cold weather shifting
- check light
- Mushrooming: Oh no, not another thread!
- CVT Fluid Change
- THE worst loose wire of all!!!
- Seat belt is stuck on the seat raising/lowering lever and will not release
- Rattling anyone?
- Driving Light Housing
- Buzz sound over left shoulder?
- tranny fluid
- Check Engine Light help
- best shop manual?
- Idle engine issues
- Documenting Wiper Motor Problems
- Back-up alarm problems?
- Do I need a new belt tensioner?
- Studder at a stop...
- hood wont pop
- Suction vs Draining Oil
- 92 octane
- This is weird
- shrill noise when starting in under 10 degree weather?
- Transmission help - out of warranty, bad bearing, replace the whole box?
- iPod Nano Weirdness
- wheel bolt torque?
- Top side oil changer
- Damn! Had a bent shift fork in my transmission!
- Funky sound from right rear...
- Low Fuel Problem - Nav Related?
- Replacing transmission
- HELP!!! Horrible Shudder in 1st and 2nd
- Occasional Driver's Door Lock Problem
- Engine Coolant
- Routine Maintenance
- MCSa Engine Tuning?
- Under Dash Facia
- Skidplate Hardware Help
- show of hands....
- brake question
- Manifold Pressure Sensor failure -Filter oil contamination?
- OK....so let's rehash this whole NGK plug thing again.
- drain plug specs
- magnetic drain plug
- Oil or Water Temp?
- Is there anyone out there who HAS NOT had MC/MCS problems?
- now no speedo!?...service in Roch, NY?...
- Cheapest place to purchase power steering pump?
- Can or Has anyone run E-85 in their Mini???
- extended maint. upgrade program
- Pela Oil Extractor
- Concerned about window regulators during icey conditions?
- my hatch will not open !!
- Shavings in gear oil
- I Need Help With This One - Check Filler Cap
- Dings and lifting of door sill Cooper S plate
- Cold weather performance?
- what am i doing wrong?
- Need quick answer
- Optima Red Cap for the MC?
- Harbor Freight OBD 2 tool for $49.95
- Foil bonnet insulation?
- OBD 2 Code P0442
- Squeeeeeeeeek !
- missing fuse...
- festival of lights.....and more!
- Battey Change
- Warranty vs Modifications
- Glove box door fix??
- oil got black really fast...
- Emailed and Heard From John Cooper Works in the UK
- Battery Problems
- Good independent auto shops in NJ?
- CVT Belt replacment
- Oil in Intercooler Normal?
- Tomioka Racing Super Slopes
- Manual transmission question, 06 MCS
- adding JCW or Helix injectors, is anything done to the ECU?
- Follow up to clutch/transmission problems
- AC and CC error codes on automatic climate control unit
- Oil Change Frequency Poll
- Cleaning under the hood
- Help. Clicking Noise!
- If I lower my window it gets dirty !
- Window motors: Has anyone replaced themselves?
- Weird noise when I release the clutch and accelerate
- Steering wheel click?
- cost of spark plug change at dealer
- CVT stalling?
- Knocking whenever I press the gas.
- bonnet / boot open alarm
- Fuel Tank Vent Valve
- Engine Sludge?
- HELP! 3rd Gear 5,000+ Noise from back.
- Caution! MEAN MINI!!!
- Resetting the ECU
- Oil - to change or not to change? That is the question.
- New K&N Air Filter
- oil drain plug - must be replaced?
- Dinan software anyone had/ have issues?
- Milky oil in coolant bottle!
- Battery Replacement Campaign-Cooper?
- JCW kit. Removed Parts Ownership. Aussie Newbie
- MCSa Not shifting smoothly....
- Fuel gauge busted
- Clutch & Flywheel
- Battery/Electrical Issue
- Warranty Question
- best spot for stands
- post storage start up procedure?
- Upgraded to 15% pulley - who's been reliable and who has had problems.
- What is this?
- Remove Alta crank pulley?
- Misfiring and other problems - bypass valve?
- Factory Paint Or Bonnet In Color
- buy stock parts online?
- mustang question
- Front Speakers going out
- Seat recline not working
- strange beep when accelerating from stop
- Wet_Clutch
- Need Help!! Stripped Oil Filter Bolt :(
- Why did my temperature read out flash?
- Delayed Engine Response
- Service Engine Soon Light
- Arg Help! Alta s/c pulley removal!
- Help I Can't Get Out of My Car
- Problems with Service at South Bay Mini (sorry, long rant)
- Is this mushrooming?
- Service in DC?
- If you want to know if DSC is a good idea... Let's look at some data!
- New Transmission Already?
- Inspection expectation?
- Which 380CC injectors to buy?
- Oil Change
- Experience adjusting the MINI's doors?
- '02S-Brief power cut-out
- disengaging auto locks
- #1 Piston no compression, why??
- Radiator fan won't turn-off
- Clutch replacement pricing
- Where to buy Redline oil???
- Died while on highway
- Ethanol
- Rebuilt Electric Power Steering Pumps
- Oil Change Indicator lying? MINI refusing to perform an in waranty oil change
- Knocking/clattering at idle only...
- Heated Passenger Seat Issue
- Driver door won't open!!!
- Windshield Wiper help
- 2003 Cooper S rear washer fault.
- Timing Chain..?
- Is the '07 CVT w/Steptronic Mode improved over '06, '05 and '04 versions?
- Looking for Rhino Ramps?
- injector failure?
- Right plug torque?
- Arizona MINI's - Using GC 0w30 year round?
- I opened a can of worms...
- Please Help!!! Valve Cover Grenade!!!
- bent strut
- Harmonic balancer
- Disabling Security Motion Alarm
- Dealer service - Great to POOR overnight
- Exhaust Leak
- Strange power cut at the track this weekend
- Elctrical coincidence?
- front end noise
- Rough idle
- Random Instrument Failure
- Wing mirror disassembly
- MINI logo on key
- 22K "first" service visit
- Pics of my Cold Air Intake Install!!
- Changing Airfilter
- Red Top Optima Install.
- Clutch/tranny/???
- Is MINI's radiator design different?
- Front Wheel Noise
- Going in for first service soon, any tips?
- Exhaust question
- Unidentified noise. Help!
- Releasing pulley tensioner without tool
- This is ridiculous!!!!!
- HELP!!! Idler pulley in southern vermont?
- Pully ??
- Has anyone had a problem like this?
- Roll Squeak. Roll Squeak.
- Phantom Misfire?
- Ticking time-bomb?
- Trying not to panic...
- I Need Help!
- Headlight out - the first thing to go wrong with my MINI
- Mis-aligned Hatch
- Question regarding part
- PCV valve noise?
- Hanger question
- BPV maintainance?
- '04 MC sluggish when cold
- Parking Brake Drag
- 2003 MINI Cooper Water Leak
- Squeeky shifter
- Blown #2 spark plug
- Will running a Helix 19% void my warranty???
- K&N airfilter
- Fuel additives are that bad?
- Disable brake pad sensor
- Headlights stopped working!!!
- Crazy temp and rpm gauges and error lights on
- I want a very loud horn. I'm sick of not being noticed.
- fuel pump squeal....
- Idler pulley?
- Underhood noise
- List of Service / Check items?
- What is a P1684?
- Brake Fluid
- Tips on fixing a very slight mushrooming of my strut towers
- Xenon headlights?
- moaning noise..help!
- Headlight Washer Problem...
- Need help car feels strange
