wipers are crap!!
I have had PIAAs now for about a month, been through a couple bits of nasty weather, and personally, I love them!
-Paul!
DJD
Winter in Kansas City is brutal on any wipers, regardless the brand. My OEM wipers work pretty well, considering all the grime and salt!
I have found that preping the windshield makes lots of difference. Rain-X works well.
I use PIAA Silicone 17" and they are beautiful... silent, no judder and fit perfectly. Bought mine from http://www.myminiparts.com/
I agree with dimini, prep is the key. Next time you wash you car, run your bare fingers over the windshield just like an OC detailer does his paint. You are feeling for tiny little bits of grit and sap and anything that is not smooth.
You can claybar you windshield, but I have found that taking a flat razor (Home Depot about four inches wide with a plastic handle) and some soapy water and using it like an ice scraper will make your windshield very slick. Be careful with the razor near your rubber seals.
Also everytime you wash, be sure to raise your wiper blades and run your fingers down the rubber edge. Any roughness means you have some grit embedded or maybe a chunck of rubber is missing... any of this will give you a streaky result or worse, one tiny grain of sand embedded in the rubber can permanently scratch your windshield.
Most of the time I run my fingernail down the edge of the rubber part feeling for grit and hopefully dislodging it.
Contrary to some, I like RainX. I use the stuff directly out of the bottle and put at least two coats on. Then the hard part... you need to polish it off, and off, and off, until there is no haze. I don't add water when I polish. Also put some RainX on a paper towel and directly wipe down your rubber blades.
Most of the time I don't even turn on my wipers (not necessary) unless it is a real frog strangler.
Just my obversations.
YD
YD
also, if your wiper blades are a bit worn, you can always "refresh" them with a rag with some vinegar on them, it only works a couple times, but helps extend their life. The vinegar eats the rubber away a bit, but it smooths the edge out.
R50/53 Help please.. Odd issue.
PsychoRallye
21
Feb 17, 2019 06:08 AM
XsV
24
Sep 30, 2015 03:17 PM
Samhillrocks
Sep 29, 2015 12:55 PM
