PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. How to Replace Radiator Fan assembly?
  2. whinny sounds from under the hood and when ac is on
  3. Rust Perforation Waranty NIGHTMARE
  4. Lots of warning lights going on and off
  5. Passenger seat airbag switch
  6. clicking or tapping arround sun roof and rear glass
  7. EP light??
  8. Car Shakes Only Under Acceleration and Only Above 60?
  9. Looking for a good MINI mechanic in Florida for a slipping clutch....
  10. 02 MCS, has some issues, ideas?
  11. Head gasket replacement questions
  12. Front control arm bushings... how much is too much?
  13. Tire light keeps comes on uphill
  14. 04' MC passenger side brake light went out and need help replacing it.
  15. Cylinder 1 Misfire... Which is Cylinder 1?!
  16. What noise is my '06 MCSa making?!?!
  17. Need help engine won't start
  18. what kind of washer is used to connect the front side markers
  19. Coins stuck in door panel
  20. Need OBD code help
  21. 04 S Battery or Alternator
  22. Exhaust smoking...
  23. MINI HATES my gf, door shocks her
  24. Extended warranty from MINI --worth it?
  25. Tire ballance and rotation covered by maintenance plan?
  26. HELP: Spontaneous shut off!
  27. Squeaky Steering Wheel/Column
  28. Thinking clutch?
  29. Anemic performance after tune-up
  30. Need new headliner any ideas?
  31. Wet headliner
  32. oil soaked paper air filter
  33. Replacing Rear Lights, OEM Retrofit Kit
  34. Oily Air Cleaner Element
  35. EML Light after Traffic Jam?
  36. Rough idle
  37. Ok to drive with Vacuum leak?
  38. Transmission sounds
  39. Broken Control Arm Bushing... How is this affecting me?
  40. Timing Chain Breakage questions
  41. intake noise problem - no changes to stock
  42. thermostat replaced - normal temperature?
  43. Front Lower Control Arm Bushing Replacement
  44. Rain sensor troubles
  45. Mysterious oil leak?!...
  46. Does a low mileage MINI need special care
  47. Exhaust leak?
  48. Acelerator vibration
  49. DIY CV joint info and/or service manual recommendations
  50. Driver-Side Window (Mangled Cabling)
  51. Battery Keeps Draining/ECU replaced
  52. Fail start
  53. Radiator Replacement: Anyone have a "how to"?
  54. Intermittent Power Steering Failure
  55. AC is smelly
  56. DIY Do it yourself Oil Pan Gasket Replacement Instructions!
  57. Another Overheating case
  58. umm. what the #$#$ is wrong with my front suspension?
  59. Throttle COMPLETELY shut off at 2nd.
  60. Engine squel in idle
  61. Oil Mystery
  62. door lube
  63. P2096 Code Question
  64. shaft seal leak!
  65. Transmission U/G
  66. Does the radiator relate to the air conditioner?
  67. 04 manual tranny difficult to shift
  68. How do you know if CLUTCH is going?
  69. Overheating Issue
  70. 2005 Cooper S gas cap lock actuator
  71. speedometer problem
  72. New to Mini's! I Need Your Opinion!
  73. LSD Oil replacement
  74. Timing chain
  75. wheel bearing replacement
  76. Engine flat spots at 2,000 - 3,000 RPM
  77. Replacement Cigarette lighter housing?
  78. Potential 2002 owner... concerned about tranny "groan"
  79. SES light on but no code
  80. OEM battery to Optima 34R
  81. Tranny Question.....
  82. Stuck cd
  83. Grinding noise?
  84. Help diagnose strange sound
  85. Engine Warning / Scan Code P113C
  86. Fan making noise/ ticking, Need help
  87. Mushroom fix updates?
  88. paipuky like vibration problem
  89. Xenon Headlight Issues, Please Help
  90. TPM on the 08 Cabrio
  91. antifreeze
  92. 2002 MINI Cooper S idle problem
  93. Are there GHOSTS in my MINI?
  94. Three groaning issues and a worried MINI owner
  95. Brake squeaking?
  96. Brake booster push rod free play adjustment?
  97. Wheel Sensor Location
  98. Front bearing noise
  99. DIY help please!
  100. Traction light comes on and stays on
  101. Help - oil leak!
  102. Caliper Frozen - Help
  103. Fan price
  104. Missing wiring for lights?
  105. Where's my ripcord
  106. Buying a 2005 MINI Convertible
  107. Car issues
  108. DSC, flat, ABS lights all on
  109. Cruise control light flashing
  110. DIY CVT fluid change
  111. Vibration in heavy rain
  112. Turn Signal Lamp Stuck On!
  113. Brakes in MCS - not effective w/same pedal pressure
  114. Need help, Throttle Body
  115. Replacing windshield advice for MINI owners...
  116. Radiator fan...
  117. Crank sensor O ring replacement
  118. 2002 R53 power steering reservoir replacement
  119. Lots of minor problems
  120. Random ABS Failure
  121. My first DIY oil change
  122. Window motor replacement how to?
  123. All glass removal PDF, plus some trim removal help
  124. Engine silent block?
  125. New MCS owner... a few questions.
  126. Head gasket diagnosis
  127. Belt Tensioner Problem or Belt Size Wrong?
  128. 03 mini issues with tachometer display
  129. Lurch from idle
  130. Xenon aiming sensor damaged. Need advice...
  131. Shorted Lighter Plug still dead even after replacing fuse
  132. Throttle error codes..?
  133. Is Rear Camber Adjustable on '05 MCS?
  134. Parking lamp
  135. Driver side window and door lock motor
  136. OK to drive (in rain) w/out A-pillar cover?
  137. Leaking coolant hoses - fixes?
  138. Charging system/alternator issue... replacement alternator died in 11 days!
  139. Dealer replaced radio, now no MP3 suppport!
  140. Stinkin' A/C!
  141. $500 Oil pan gasket=too much?
  142. Weird sound at start up
  143. Power steering fan stays on with motor off
  144. 2005 MINI Cooper S leaking antifreeze! Please help!
  145. Coolant expansion tank cap
  146. Tank O'Seafoam - engine's not happy...
  147. OBD2 P1109
  148. Down tubes on center stack?
  149. Passenger door lock
  150. MCS belt tensioner – is it possible to buy the little damper separately anywhere?
  151. She's come unhung
  152. MCS front battery post dead in the water
  153. How do you lube the chassis?
  154. R56 auto transmission jumps out of gear??
  155. Intermittent air conditioning
  156. 05 MCSa losing power steering and gauges with hard turns
  157. My lovely MCS 06 model. Yeah right!
  158. Fault p1476? Leakage diagnostic pump clamped tube?
  159. Triptronic 06 MCS 93K needs to be changed
  160. Strange warning light showed up on my car today...
  161. Good news about MINI service
  162. Oh no, what have I done! Stalling after start
  163. Control panel doubt
  164. Squeaky gas pedal?
  165. Experiences w/ Fidelity Warranty Services?
  166. Urgent help needed! Oil filter stuck!
  167. CEL and gas cap light after fuel filter change
  168. Downshifted and suddenly lost power & EML/SES/DSC lights on
  169. Knock/clank
  170. R53 belt failure - help?
  171. Is this a bad BPV?
  172. Brake pad wear question
  173. Limp mode throwing codes P0107 & P1688
  174. Issue w/indicator lights
  175. Hatchback electrical issue...
  176. Fuel pump/filter/sensor/indicator?
  177. Rear seat catch mechanism
  178. Door Issues
  179. Help with oil pressure & water temp gauges
  180. Third brake light on with car off
  181. Strange clutch sound
  182. Couple of concerns 06 R53
  183. Possible faulty master cylinder?
  184. Engine braking problem
  185. p0300 codes
  186. Key failure
  187. Hatchback door latch issue
  188. Rattling/Chattering/Gurgling when Idle - 2004 Cooper Auto non-S
  189. Charging system error - alternator replacement - 2004 Cooper (non-S)
  190. Aftermarket tranny oil
  191. Dealership won't fix brake booster. What do I do?
  192. Squeaking door when warming/cooling
  193. Squeaky Suspension
  194. CEL on 06 MCS, no one but dealer finds code, wants $1300 to replace engine harness?
  195. Gasket/seal question?
  196. DIY oil pan gasket change?
  197. AC issues
  198. What color should oil be after change
  199. Something important fell in the hole
  200. Noise after control arm bushing install
  201. 05 MCS radiator support
  202. Replacing headlight washer
  203. Diagnose this
  204. Grrr! Paint chipping!
  205. Question?
  206. Driver's door lock AND interior lighting issue - related?
  207. Removing OEM Aero rear bumper decals...
  208. 4 OBD codes, fuse replaced, now misfire?
  209. Fuel pump madness
  210. Code 2096 running lean, help diagnose please
  211. Power Flex Bushings
  212. temp sender location
  213. Electrical hell
  214. A/C acting up
  215. Source for OE body parts
  216. What does the DME module do...
  217. Good place to get replacement parts
  218. R53 brakes hissing
  219. MINI battery, dealer and warranty woes!
  220. A CVT problem?
  221. A CVT problem?
  222. Dash de-squeaking / disassembly writeup
  223. Calling all NAM for help
  224. Electrical / Start Problem - Please Help!
  225. Where is my oil going?
  226. DSC, SES, EML lights on!
  227. Engine rattle/tapping when hitting 3k RPM
  228. Steering rack clunk, PS hose leak, dip stick leak!
  229. Alternator recognition problem
  230. Foot on gas pedal yet nothing happens...
  231. Replaced my thermostat
  232. Misfire symptom and solution
  233. Who has had to replace their supercharger?
  234. Dome light keeps flashing while driving... why?
  235. Seafoam, oil change right after?
  236. Part # confirmation
  237. Hit a curb! Help!
  238. Cruise control inoperable - need technical help from a BMW/MINI tech
  239. Crap...
  240. Things that break after warranty ends
  241. Loose steering/wander feel at 42,xxx miles
  242. Should there be thread sealer on brake bleed screw?
  243. Dropping sub-frame
  244. HID headlight out, and solution
  245. Rear Main Seal sadness...
  246. Stiff MT shifter 2006 Cooper
  247. My driver door won't open
  248. I need help fast, overheating
  249. Bad coil and DCM computer
  250. Recalls
