Hatchback door latch issue
Old Mar 18, 2009 | 02:44 PM
mscmagno's Avatar
mscmagno
i have this problem since i just didint bother , asking hot to get fix, but since im having to much prblem with my car now, i draw my attention to the door latch at the back. whenever i try to open the door at the back it make this noise ( rattling or buzzing sound) everytime i press the latch at the back, i have no prblem closing the door or opening it just that noise somtime annoys me, do anyone have same problem with that? and is their any fix to it..
Old Mar 18, 2009 | 03:00 PM
mitch171's Avatar
mitch171
Proof read please...
I don't really have any idea what you are trying to ask.
Old Mar 18, 2009 | 04:16 PM
mscmagno's Avatar
mscmagno
opps sorry , anyways i was saying, i have a problem with the opening mechanism at my rear door, whenever i pop the back door it make this rattling sound or buzzing sound, seems to be the sound is coming from the lock, I tried pressing the release button on the door while the its open and it start buzzing, do anyone have same problem or do anyone find any fix to it?
Old Mar 18, 2009 | 04:32 PM
100percentcotton's Avatar
100percentcotton
If I hold the release button for like a second too long the lock tries to rapidly release and sounds kind of like a machine gun. Is that similar to what yours does?
Old Mar 19, 2009 | 02:00 PM
mscmagno's Avatar
mscmagno
YES!! you got that right!.. did able to get fix it or find a way fix it?
Old Mar 19, 2009 | 05:13 PM
100percentcotton
Nope, I just live with it. I haven't tried to fix it though. Mine only does it if you hold the release button for more than a second, so it really doesn't happen too often.
Old Mar 19, 2009 | 06:54 PM
ClubmanS's Avatar
ClubmanS
What year is your car?
I remember having this problem with our 2002 MINI. THe electric hatch latches of the early cars were problematic to say the least.
Old Mar 19, 2009 | 06:59 PM
ClubmanS's Avatar
ClubmanS
You need to get it re-programmed. The early cars came from the factory with the option to open the rear hatch by pushing on the keyfob MINI wings button for 5 seconds. That never worked as it caused the electric latch in the hatch to ratchet like a toy gun. Either the hatch would fail to open (get stuck) or the latch would self destroy preventing you from safely closing the latch.
MINI issued an internal bulletin back in 2002 instructing dealers to remove the 5-second keyfob option and reprogram the fobs to open the windows/sunroof instead when pressing and holding the wings button for 5 seconds.
In 2005, MINI supplied a 3 button BMW key that allows you to open the rear hatch independently from the rest of the car.
Old Mar 20, 2009 | 12:21 PM
mscmagno's Avatar
mscmagno
so you mean, if i press the keyfob for more than 5 seconds it will open my backdoor? but that dont happen, it only open my passenger door and roll down my window and open my sunroof.
so in this case i have 2003 MCS , and i have to bring it to the dealer to reprogram my key Fob to remove the autmotic back door opener and that will fix it? is thier anyother way to reprogram it my self?
Old Mar 20, 2009 | 12:28 PM
ClubmanS's Avatar
ClubmanS
Well if you press down the keyfob button for 5 seconds and both windows roll down and sunroof open, then it is already programmed like that possibly from factory.
Since you have a 2003, you have the older Rover style 2 button keyfob. You don't really want to have enable the 5 second press and hold to just open the rear hatch. Like I said that never worked and MINI promptly removed that programming option in later 2003 and 2004 MINIs.
Only your dealer (Or an independent MINI mechanic) with a GT-1 handheld computer ($15K piece of equipment) can access the ECU (Plugs underneath the dashboard on the driver's side) in your car and make those changes. You can't do it yourself.
Old Apr 14, 2009 | 09:40 PM
GTV's Avatar
GTV
Strange thing - this happens to my 5 series E39 also, but I live with it since the trunk opens normally with that "machine gun" sound and stays lock when I want it to.
Southern Marylander
Jan 14, 2019 06:05 PM
eastport_mini
General Mini related Ads
Mar 28, 2016 08:35 PM
Knuckle14
Aug 26, 2015 08:10 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
