Things that break after warranty ends
My 03 MCS has been perfect for the 4 years under warranty, but as soon as it ended things started to fall apart!
total mileage: 50k
things that broke over 2 years after expiration date
1. driver door lock failed
2. window doesn't roll down in the summer
3. boot would not open in temp. above 45 degrees F
4. sound system cannot produce proper bass or treble anymore
5. the clutch makes a weird sensation like its grinding on braided steel from about 30-60% pushed in
6. sunroof started to rattle
7. exhuast rattles below 2100 rpm
8. requires lots of force to shift shifter
9. windshield cracked
total mileage: 50k
total mileage: 50k
total mileage: 50k
2. Try hitting the area above your speaker. It's usually debris in the window motor and knocking at it helps a lot. It actually fixed my window motor, and it's been working for about a year now.
5. I have the same problem, and my mechanic told me that LuK Clutches are ticking time bombs, and you won't know when their going to go out. Others say that it's a good indication that you need a clutch replacement soon. I ordered my CM Fx2oo and CM Flywheel recently and getting ready to install that soon.
8. That can be fixed with lubrication at certain places. Transmission fluid can also play a major role.
9. Normal wear and tear. Some states such as Massachusetts, covers windshield replacement once a year.
Something else you'd have to keep an eye out for:
-Power Steering Fan and Pump. Watch the fan, if the fan dies, it'll eventually lead to a dead pump which is costly.
-Supercharger. Have a mechanic who specializes in MINIs to do a maintenance on it at higher mileage ~100K. The oil in the supercharger gets sucked out eventually and the gears would self destruct.
Good Luck.
At 51k this happened:
water pump went = new super charger
ecu fried (shop still can't get back on road after 45 days)
compressor died
belt tensioner - twice
window does not seal right makes wind noise
POS
compressor died
POS
I've been bitten by a number of these issues which is why I'll never buy another BMW vehicle again. It's potentially a great vehicle but BMW's lack or R&D or cutting corners has resulted in many dissatisfied owners. All these expensive repairs overshadow it's thrills.
minipopkart
Aug 13, 2015 05:22 AM
