Suspension JCW Pro coilover unboxing
Old Aug 11, 2015 | 08:09 AM
Ryephile's Avatar
Ryephile
I decided that for now I'm going to opt for an "OEM+" motif for my JCW. Part of that decision was centered around the fact that the new JCW Pro coilover offering is in fact built by KW, yet still comes with a MINIUSA warranty that spans the new car warranty. Motor City MINI gave me a lovely package price with the coilovers when buying the JCW, so it was an easy decision. Keep in mind the JCW is my daily driver, and I have my turbo Miata built up as the hardcore Hoosier-shod track car, so a dollop of comfort with sporting intentions are the theme here.
The bigger-than normal box fits comfortably in the F56's larger boot. :biggrin5:
JCW Pro coilovers unboxing by Ryephile, on Flickr
The part number is 33502361197 for "retrofit kit sports suspension" (for cars without DDC)
A very nice microfiber bag holds the spring perch adjuster wrench
A little more unpacking shows the foam-wrapped rear springs, thread-locker compound, "Attention: John Cooper Works sport suspension installed" sticker (LOL), and front struts, the expanding foam keeping everything night and snug.
Here's an up-close of the stainless steel front strut, the stickers indicate "Left" and "Right" sides, and the "made by KW" clearly marked.
Here are the dampers and springs all together on the bench. The rear bumpstops have new dust boots snapped into them. I presume the fronts will re-use the original dust boot bellows
The rear springs, rear height adjusters with very nice rubber noise isolators, thread locker, wrench, and sticker. Where should the sticker go? :confused5:
Close up of the rear height adjuster. It's nicely anodized aluminum, likely right off the shelf at KW but anodized black instead of purple. The rubber isolator is actually a very OEM looking 2-piece design that plugs into the coil spring end.
In all it's a very nice looking kit. It's clear it's had an OEM touch over the normal KW offerings, which is a big plus. I'll post more information on the stroke and bumpstops when I remove the stock bits to have a solid comparison.
Old Aug 11, 2015 | 09:11 AM
F55MidnightBlackCooperS's Avatar
When is the install?
I plan to run maximum extension to get full travel.
will post pic of mine friday.
Old Aug 11, 2015 | 09:29 AM
Ryephile's Avatar
Ryephile
I'm installing them tonight along with doing a detailed stroke and bumpstop analysis on both stock SS and these.
Your comment makes little sense. Do you mean you want maximum compression stroke? No matter where the ride height lands, you still get full stroke, it just might not be effective. If you want good handling you need the ride height located most commonly at approximately the halfway point of the total stroke, and usually FF mac-strut cars end up being quicker with slightly more droop than compression to maintain tire contact during braking and body roll. Of course this is assuming the roll centers are in rational locations. Suspension setup is complicated and highly dynamic, experience helps tremendously.
There isn't a large amount of adjustment on the rear spring perch, about an inch. There is a functional sweet spot and I'll let you know where that is tomorrow.
Old Aug 11, 2015 | 10:05 AM
thanks
Old Aug 12, 2015 | 06:59 AM
Ryephile's Avatar
Ryephile
Ok I got the analysis done and the coilovers installed, but I haven't had time to drive it yet and the ride height still has to be sorted out.
Pictures first. Here are the rear SS [black] and JCW [red] springs. The JCW spring wire is much thicker, but there are also more turns and thus longer wire length, so the final spring rate might be similar.
OEM Sport vs JCW accessory suspension by Ryephile, on Flickr
One of each disassembled rear dampers, SS on left, JCW on right. Note the much different bumpstop size.
One of each assembled rear dampers, SS on left, JCW on right. The mounting surfaces of the top-moutns are lined up; note the JCW is shorter overall.
Front spring comparison, JCW [red] on left, SS [black] on right. Even though the JCW is wound shorter, it still has approximately 4 turns total. The JCW wire is about the same thickness, but the coil turn diameter is generally less, meaning a shorter overall wire length which means a stiffer spring. This is all assuming the wire alloy is similar, which is very well may not be.
Front strut comparison. JCW [stainless] on left, SS [black] on right. SS bumpstop not shown here, but it's much bigger than the JCW bumpstop. Of note is the SS damper has surplus damper shaft, meaning at maximum possible stroke there's still some chrome damper shaft outside the body. This is important later on with the stroke analysis.
Here's a picture of the stock SS front strut installed in the car w/out the spring. This allows me to measure axle location at full droop, at first bumpstop contact [which I also call "free compression stroke", and compressing the bumpstop until the car lifts off its respective corner jackstand, putting the corner weight of the car into compressing the bumpstop. This demonstrates an approximation of full travel in a static situation, however dynamically [e.g. slamming into a speed bump] the bumpstop would compress slightly further, as indicated by it's typically unpublished rate vs. travel graph.
I did these measurements on one side of the front and rear.
Here is a picture of a partially assembled JCW front strut, after doing stroke measurements.
...and finally something installed in the car!
numbers to follow
Old Aug 12, 2015 | 07:12 AM
Can't wait to get your final settings for ride height.How much closer is wheel/tire to front strut assembly?
Old Aug 12, 2015 | 07:45 AM
Ryephile's Avatar
Ryephile
Here goes. I'll try to make my nomenclature easy to understand by starting with some definitions.
*Static ride height: The position the suspension sits when the car is parked. For this car, I'm using the centerline of the axle to the apex of the wheel arch trim directly vertical from the centerline of the axle.
*Droop: The amount the wheel sags or extends [e.g. when the tire falls into a pothole] compared to the static ride height. This will show more tire gap between the tire and the fender arch
*Compression: The amount the wheel pushes into the body's wheel housing [e.g. when you run over a bump]. This will show less tire gap between the tire and the fender arch
*Bumpstop: A carefully design micro-cellular foam piece that helps exponentially cushion the damper during large compression actions [e.g. a very large speed bump or too many fat American's climbing aboard]. The bumpstop usually compresses to between 1/3 to 1/4 it's normal height when the weight of the car is on it, depending on stiffness and design. Keep in mind that when the bumpstop is compressing the added spring rate exponentially approaches infinity. The bigger the bump, the harder the shock transferred into the cabin. The goal for bumpstop design is two-fold; to not allow the damper to bottom-out its internal bits, and to absorb enough force such that the largest intended impact does not exceed the point of the bumpstops compression curve where it approaches infinity. Sounds simple, right?
*Motion ratio: The difference in stroke between how far the damper moves and how far the tire moves. Thankfully for the MINI, the damper motion ratios are basically 1:1, so they're not of concern. The rear spring on the MINI does have a motion ratio other than 1:1, but that's not something we'll touch on here.
__________________________________________________ _____________
Stock Sport Suspension:
Droop @ 17.375" front and 16.5" rear
Ride Height @ 14.75" front and 14.375" rear
Free Compression @ 13.75" front and 13.125" rear
Bumpstop Compression @ 11.875" front and 11.625" rear
Put into a different context:
Total Possible Stroke is 5.5" front and 4.875" rear.
From Ride Height to full Droop is 2.625" front and 2.125" rear
From Ride Height to first bumpstop contact, or "free compression travel" is 1.0" front and 1.25" rear.
Full bumpstop compression adds another 1.875" front and 1.5" rear of compression travel, but it won't be comfortable.
JCW Accessory suspension kit by KW
Droop @ 16.625" front and 15.625" rear
Ride Height to be determined, however 13.5"-13.875" front and 13.25"-13.5" rear appears to be design breadth
Free Compression @ 12.5" front and 12.0" rear
Bumpstop Compression @ 11.0" front and 10.75" rear
Total Possible Stroke is 5.625" front and 4.875" rear.
Full bumpstop compression adds another 1.5" front and 1.25" rear of compression travel, but it won't be comfortable.
What can we learn from these numbers? Put it into a very simple statement, the JCW coilovers offer the ability to lower the ride height 1.25" front and 1.125" rear with zero compromise to compression ride comfort versus the OEM Sport Suspension. The bumpstops are shorter and thus more progressive, yet I'd wager the difference in very large bumps will feel basically the same. The total stroke of the JCW setup is actually slightly more in front and identical in rear, and the design intent is to locate the ride height between 7/8" and 1.25" lower than stock without any noteworthy compromise in ride comfort.
It'll be a few days before I'll be able to give quality feedback on the final ride height and dynamic behavior, but rest assured I'll update this thread when I do!
Cheers,
Ryan
Old Aug 12, 2015 | 07:58 AM
Ryephile's Avatar
Ryephile
So basically, the design range is 7/8" to 1.25" lower than stock. The front threads allow for almost stock height, but that really messes up the droop travel so the car will have poor grip on the inside front in every corner. The rear adjuster has little adjustment so you can't get it too wrong there. Unfortunately the kit has NO instructions (probably just for the service department), so when I get the adjusters dialed in I'll post it so there's no mystery when everyone else installs theirs.
Old Aug 12, 2015 | 08:05 AM
Would a setting in the middle be a good place to start?
Old Aug 12, 2015 | 08:22 AM
Ryephile's Avatar
Ryephile
The short answer is yes, but I'll provide a more specific answer tomorrow. Also, my answer will be applicable for the F56 non-sunroof JCW, so your F55 will likely need more rear spring pre-load to achieve the same ride height, given the slightly additional weight.
Old Aug 12, 2015 | 08:40 AM
middle front 1/3 down in rear?
Old Aug 12, 2015 | 08:59 AM
Ryephile's Avatar
Ryephile
Guessing isn't going to help. Wait until I actually measure it.
Old Aug 12, 2015 | 09:05 AM
very true. thanks for info and looking forward to your next post. Can't wait until my install on friday.
Racechip should be here in the next 2 hours and car is ready for install of unit.
Old Aug 12, 2015 | 09:16 AM
Ryephile's Avatar
Ryephile
Yup no problem. I'll post the info as soon as I have it.
Oh Racechip? Please make a thread or post in the Engine sub-forum for how that turns out, I'd like to hear about it.
Old Aug 12, 2015 | 07:35 PM
Ryephile's Avatar
Ryephile
Here's how I set the car up tonight:
The "axle center to wheel arch apex" ride height is set for 13.6" front and 13.2" rear, the same chassis rake as stock, but 1.1" lower than stock. I haven't yet analyzed the roll centers, so this might not be ideal for handling, just FYI.
JCW Pro coilovers installed by Ryephile, on Flickr
And here's how the spring collars look. In front there are 25 threads of useful adjustment available. I set the collars so there are 10 threads visible below the collar, or 0.75" of exposed thread. In the back, it's "full down", with 0 threads visible.
How does it ride and handle? Well, I drove it a whopping 2 miles through my neighborhood tonight, so my impressions are minimal. The ride feels pretty much the same, maybe 20% firmer due to stronger damping. The stock Sport Suspension IMO was lusciously soft and didn't seem fitting for a MINI, even a grown-up refined MINI-BMW like the F56. These JCW Pro coilovers aren't a drastic change, but they're a small step in the right direction. I'm not sure if my mother would even notice the change from inside the cabin.
I will be driving the car tomorrow, so I'll try to provide more thorough feedback then. First impressions are good; the ride quality isn't ruined at least, and the car looks a whole lot better not sitting on the factory lift-kit.
Old Aug 13, 2015 | 08:41 AM
RDSJCW's Avatar
RDSJCW
Jcw part #
Hello,
looks great & nice write up! I just ordered 16 JCW & also am ordering the same coilover kit. Your part # in the txt. does not match the part # on the box? Also can u tell me how much you paid? My dealer is around $1600.00.Thanks Rich
Old Aug 13, 2015 | 08:50 AM
papawhiskey's Avatar
papawhiskey
Are there any adjustments with this kit for any compression or rebound damping?
Old Aug 13, 2015 | 08:51 AM
Ryephile's Avatar
Ryephile
Sorry I typo'd the part number, it's fixed now. The box part number is correct.
As for pricing, I'd rather not say for my situation, however you should definitely ask your dealer to price-match ECS or MINI of Kennesaw, as they both list the kit on their webstores for $1,465 and $1,421 respectively.
Old Aug 13, 2015 | 08:53 AM
Ryephile's Avatar
Ryephile
Nope, fixed damping, in the save vein as the KW V1's. The only adjustments are the spring pre-loads for ride height and dailing in the corner balance. This IMO is not a negative as it means the damper design can be dialed in for the car exactly and have a better valve than one that has adjustments that are easily screwed up by the customer.
If you're looking to put the car on-track and "need" the adjustments, I'd recommend going straight to the KW Clubsports. That is, unless you want to go big and have Anze build you a set of Penske's.
Old Aug 13, 2015 | 10:15 AM
Very nice write up like the KW branding right next to the JCW logo, like a MINI Challenge suspension.
Congrats on the new setup.
Old Aug 14, 2015 | 05:54 PM
Here is my F55 with the Jcw pro suspension
At Mini of Orlando
Smooth riding car even with 18s
Old Aug 14, 2015 | 08:03 PM
Zillon's Avatar
Zillon
Any plans to fix that negative rear camber, Ryan?
I'm a bit disappointed with the appearance of the stock wheels and tires on the JCW, they just look flat out goofy with the distended spokes and tiny contact patches.
Old Aug 14, 2015 | 08:26 PM
hemisedan's Avatar
hemisedan
[QUOTE=F55MidnightBlackCooperS;4113473]Here is my F55 with the Jcw pro suspension
At Mini of Orlando
How is the difference? How's the ride as well as the performance stand point? Those wheels are interesting, but I suppose that they won't clear the brake calipers though.
Old Aug 15, 2015 | 05:43 AM
[QUOTE=hemisedan;4113517]
At Mini of Orlando
Hemi the bbs will clear the jcw brakes we tested fitted one on a fjcw yesterday.The ride is oem very plush,will test performance this weekend with some on and off ramps plus the horrible section of I4 that runs through downtown orlando.
Old Aug 15, 2015 | 07:56 AM
hemisedan's Avatar
hemisedan
That sounds good! I asked on another posting, but what is the weight of these wheels? Really wish that they were 17's, but hopefully that will come later. Shucks, it's six months before I'll be taking delivery of my next Mini JCW, so I've got time yet. Can't believe that I'm getting all worked up about the next car so soon, but with you and Ryan and your JCW Pro Suspension adaptions, well it's getting me going, then you surface with a neat wheel option. Who says car stuff can't be fun?
