Another Overheating case
Old Apr 29, 2009 | 08:50 PM
bbort1's Avatar
bbort1
2005 MC with 5 speed manual. New Issue. Vehicle overheats only when stopped at idle for a few minutes, (in line at drive through lane). If I rev engine, or once I leave and drive normal speeds, temp returns to normal. I can hear radiator fan running very load when it's overheating, and after I turn the engine off. It also runs loader and longer than I ever remember it running after turned off. All fuses are good, relays are good, coolant system and overflow tank are full. Oil level is good and no signs of leaking under vehicle.
Ay Ideas? Could this be water pump? What controls low speed fan?
Old Apr 29, 2009 | 09:57 PM
desmo's Avatar
desmo
Overheating?
Sounds like you might just have a bad thermostat. Also I'm not sure if your car has a two speed fan like my 03, but if it does there is a large resistor in the fan assembly that may have burnt out causing the low speed not to work.
Good Luck
Old Apr 29, 2009 | 11:00 PM
bbort1's Avatar
bbort1
wouldn't a bad thermostat just stick and not allow the emp to come back down to normal?
do you need to take the fan assembly out to find the resistor?
Old Apr 30, 2009 | 04:50 AM
katrina1581's Avatar
katrina1581
I had the same exact problem(overheat when stopped, cool down once it started moving) with my old R53, definitely a bad thermostat. I had the dealer replace mine since it was under warranty at the time. If a thermostat is bad is doesn't necessarily means that it is seized as you describe, it just does not open and close at the pressures it should. Thus when you start moving again the air coming through the radiator cools the engine and the symptoms go away.
minimofo
Dec 26, 2015 12:03 PM
rt808
Sep 29, 2015 03:15 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
silence2-38554
Sep 28, 2015 12:19 PM
rt808
Sep 25, 2015 01:59 PM
